Hey Ken H.
Mopower
09-28-2006 06:41:12
Ken,
Someone tells me you use a water jet for cutting metal. How thick can you cut through plain cold-rolled steel ...say 1018? I have some work ahead of me and I believe water is a better option in this case than laser cut. Is it CNC?
Ethan Berry
p.s. Comin' to Fowler?
ChadS
09-28-2006 07:46:57
 Re: Hey Ken H. in reply to Mopower, 09-28-2006 06:41:12
Ive seen waterjets cut 4 inches+ thick steel, fully CNC controlled. It takes a while, but does a super job.
Mopower
09-28-2006 08:20:27
 Re: Hey Ken H. in reply to ChadS, 09-28-2006 07:46:57
Can it cut tappable holes too? Say 3/4" steel?
superih
09-28-2006 15:24:34
 Re: Hey Ken H. in reply to Mopower, 09-28-2006 08:20:27
We have a water jet. Can cut 3/4" steel no problem. Piercing 3/4" no problem either. A water jet can cut anything that fits under its X axis, ours about 8 inches, Lasers cannot. If the feed rate is slow enough you could tap the holes. The advantage of a waterjet is no heat is used, doesn't change the properties of the material. They are accurate to about 0.010"
ChadS
09-28-2006 08:39:48
pin point accuracy, clean thru. Back when I was driving truck, Id haul flat steel into ENCO down in KY, they made industrial parts, Dozer blades, backhoes, loaders, buckets, you name it, they made it, and used a combo of laser for anything over 5 inches thick, and waterjets for less than 5 inches. I spent many hours waiting to get unloaded, so I had the chance to watch em cut those big plates of steel. On smaller waterjets, if the guy operating it, knows how to set it all up, it makes the parts, ready to do anything without having to repair, or modify. Does a nice job! The thing about cutting thck sttel on them is, you have to have a place to let the waterjet go thru first, it wont cut right thru, so you have to help it, so you have to drill a hole where it starts cutting, if not, you have to come in from the outside and work its way in,,, that leaves a cut line from where it starts on the edge of the steel, instead of starting where the hole needs to be,, follow me so far? A big mill can do it with a drill bit, but, how big is the steel your working with,, to be able to know if the steel will fit in the machine,, Chad
