Farmall M governor
jhb
09-27-2006 05:16:11
Does this sound like an identifiable problem? Starting down the track my M at standard rpm will rev out and start to lose power and then flies open as it gets into its power but not until it seems like it might be down to about 2/3 of maximum rpm. Once the engine opens up it will hold under steady power. The engine is turning out about 63 hp at 1600 rpm and I have a shorter spring on the governor. Where should I look for the problem. I took 2nd last week to a 400 in a 6500 pound class because I lost traction. I lost by only 4 inches. Just trying to tweak it a little more. I keep thinking one of these times it will not kick open and I will be just the same as an ordinary M in power with a sick governor.
ChadS
09-27-2006 11:34:23
 Re: Farmall M governor in reply to jhb, 09-27-2006 05:16:11
2 weight, or 4 weight governor? Yeah, id be checking the linkage for a bind,, Maybe the veritcal linkage is out of adjustment? Chad
jhb
09-27-2006 13:37:38
 Re: Farmall M governor in reply to ChadS, 09-27-2006 11:34:23
Chad, 2 weight. Vertical linkage was adjusted so that the pin fits in tight at full throttle. Thanks. Jim
ChadS
09-27-2006 13:50:02
 Re: Farmall M governor in reply to jhb, 09-27-2006 13:37:38
Check the pins in the weights,, the holes get slotted from wear, can cause a spot where it will stick,, While you have them out,, grind some of the material off, the heavier the weight, the more it wants to shut the carb down, and hold the peak rpm limits down. Chad
Todd Leslie
04-29-2007 19:45:19
 Re: Farmall M governor in reply to ChadS, 09-27-2006 13:50:02
Hello there,
I am in New Zealand (a country by Australia) and have just finished a restoration of a 1947 Farmall M A true gem it is now!!!!
I have a problem with the tractor and I believe it may be stemming from the governor and its connection with the carburettor. The tractor will only get up and cruise in 5th gear,at full throttle in all other gears it just hobills along at absolute snails pace i.e. I can walk faster. I also don't think that it is actually revving at its full at full throttle either.
I would be interested in hearing from anyone who can offer some advice with what may be wrong or how I can fix it.
Regards
Todd
PULLS MS TOO
09-27-2006 11:05:02
I had this problem was the shaft into the carb binding .Take off breather tube unhook linkage and put thiker or thinner gaskets under elbow move it on bolts etc.some loosenes in holes until shaft moves free.End that hooks to carb may need same,one end or both.
jhb
09-27-2006 11:33:25
 Re: Farmall M governor in reply to PULLS MS TOO, 09-27-2006 11:05:02
Thank you, I will try your suggestion and let you know. Jim
