MORE power for Farmall H
Morgan Hudgins
04-09-2002 17:20:14
I outpulled a bunch of people last year in stock, so the official are checking my tractor this year. All of the other guys are building their engines but I can't. Any suggestions for extra power and traction? Any tricks for gas? I heard if you cool it it will fire better? Wheels pulled out or in close? loose clay is what I am pulling on.
ff316
04-10-2002 15:46:47
 Re: MORE power for Farmall H in reply to Morgan Hudgins, 04-09-2002 17:20:14
Cool air and fuel mixture is more dense so you can pack more into the cylinder. If you can make your intake charge stay cool you will get a little more power. No suggestions on how to do that, hope you figure it out. Good luck, Fireman
dave h
04-10-2002 10:39:53
what is your ignition set up? the high voltage systems? head work? do you need more torque?Iwould look at head polishing and porting ,maybe give Motec a call to work the carb. and a hot coil. for stock type classes.
cd
04-09-2002 17:47:50
I was just wondering the same thing as to whether a "cool can" will give you much more horsepower.
