Thinking about building a AR jd ?
oskpuller 65
09-25-2006 18:25:12
Advantage or disadvantage , With this tractor, I was told today there is a AR jd in ill, that is a div 3 tractor that pulls realy well , Looking for help on this thank you mark
Dave in MN
09-25-2006 21:10:56
 Re: Thinking about building a AR jd ? in reply to oskpuller 65, 09-25-2006 18:25:12
A guy I know/pull against has a AR that is pretty strong (mostly kicked my butt every time) HOWEVER, from what I've been told, the crank for the AR wasn't a real common (cheap to come by) item and with the cost to build (I don't know how much he has it stroked) he has about $2500 in a crank. He's broken 3 and is using the 4th one.
I guess that you could get a Maytag wash macnhine motor to make big HP if you spent enough $$ on it. There's enough green tractor models that are maybe a better choice, but what the heck, it's your money!
mr.thinker
09-25-2006 21:20:40
 Re: Thinking about building a AR jd ? in reply to Dave in MN, 09-25-2006 21:10:56
you said it dave the problem is throwing the money, he'd have to use maytag part's on this ar, you'd have to know osk?
