Is a ar jd a good pulling tractor
oskpuller65
09-24-2006 08:21:59
Are there anyone pulling a AR jd in div 3 or div 2 , If so who , Would it make a good puller,
mark
buickanddeere
09-25-2006 17:28:49
 Re: Is a ar jd a good pulling tractor in reply to oskpuller65, 09-24-2006 08:21:59
Taller/narrower rowcrop 38" tires will outpull the 26/28/30" standard tires on medium to hard tracks. The short wide tires will work better on sand.
apulller
09-24-2006 12:53:07
the short standard tractors are harder to pull, but it can be done, seen a JD ao pull and it did darn good. a set of 16.9x34's fits up real nice.there a little hard to ballance as i mentioned, so you better have some places to hang weights and a few extra 50's for small movements.
oskpuller65
09-24-2006 15:50:59
 Re: Is a ar jd a good pulling tractor in reply to apulller, 09-24-2006 12:53:07
Thanks for your input on this tractor,
mark
mike's600
09-24-2006 08:52:03
I had a Jd60 orchard, didn't pull ! The balance is all wrong. It will pull about 70 feet and spin out.I pulled against and AR JD, with the 60, they both spun out in the same spot.Restore it, and take it out to a parade.
The Mod came in today, looks good, but it's going to require alot of work to get it on the track. Looks like next year's season.Thanks
oskpuller65
09-24-2006 09:03:41
 Re: Is a ar jd a good pulling tractor in reply to mike's600, 09-24-2006 08:52:03
I am glad you got home, So what do you have to do to it, I for got to send the brake pads they are new. On the ar jd what if i build a longer fron end on it and balanced it ,
oskpuller65
09-24-2006 09:24:35
 Re: Is a ar jd a good pulling tractor in reply to oskpuller65, 09-24-2006 09:03:41
Hey mike do you any pic of your hot rod tractor,
