NO PELLA IOWA PULL IN OCT. Just to be sure thnx
DPG
09-22-2006 11:19:21
Hello Pullers,
Sorry to say we ARE NOT PULLING in PELLA OCT 7th. We had taken an Ad with THE HOOK at a time when we thought it would all work together just fine. However, we"ve experienced technical difficutlies with our sled monitor this year, and in trying to conquer that problem we"ve run-out-of-time.
SO TO REPEAT: NO PULL IN PELLA OCT 7th. Out of respect to Pullers who travel hours, spend big $ to play and expect a level playing field and a well run pull, we (I) have opted to not do a pull in Pella Oct. 7th.
You Pullers deserve a "good"pull and I feel we can"t do that for you this fall. We are prideful of doing good pulls on one of the Midwests premier power-tracks.
All I ask is let others know who might be thinking about coming. I"m also doing a direct mailer regarding this to several who have been to Pella recently
However plan on next June, I"m 100% sure whatever bugs we"ve had will be exterminated!!
You"ll see this same messge posted several times the coming days.
THANKS,
DOUG
Pulling Committee Chair
PS please email concerns if you have them
green camell
09-22-2006 12:11:03
 Re: NO PELLA IOWA PULL IN OCT. Just to be sure t in reply to DPG, 09-22-2006 11:19:21
Why don't you get the kontraption sled?
Not a Fan
09-23-2006 08:43:36
 Re: NO PELLA IOWA PULL IN OCT. Just to be sure t in reply to green camell, 09-22-2006 12:11:03
Just my opinion, not sure you'd want to hire the Kontraption now, not nearly as dependable as previous owner. Too many breakdowns this year, lack of maintenance.
SE Iowa Puller
09-24-2006 20:38:24
  Kontraption Sled/Oct 7, 2006 in reply to Not a Fan, 09-23-2006 08:43:36
The Kontraption sled was re-powered over the winter to a diesel Hydro unit away from the ProPAIN 350. Gonna have bugs to work out. There are also planning more upgrades this winter. On a side note, The Kontraption sled will be at Mcmillan Park in Mt. Pleasant Iowa that evening. The Donnelson Pull was cancelled and we are working at getting this moved to Mt. Pleasant. Show will start at 5 pm. ANY TRUCKS WELCOME. There will be classes ranging from Pure Street, Street Stock, Pro Street, Street Diesel, Pro Diesel, Modified and Open. This is the end of the year Pull. Passes will be $10 each with Children 10 and under free. All Hooks are $10 each.
Call Lon Newton at 319-837-6962 or Michael Miller at 641-693-4030 for additional details.
