John Deere pullers rejoice!
Its here!
09-21-2006 15:07:10
Just finished the prototype for the limited slip differential for the JD, A B,G on up! This is not good news for pullers that would have to pull against a JD thats got some advantage! No more riding the brakes to keep one wheel from spinning out. Good luck pullers!
B Barenie
09-21-2006 18:37:28
 Re: John Deere pullers rejoice! in reply to Its here! , 09-21-2006 15:07:10
Call Earl Steineiger
574-893-7437
He's been doing it for years !
What about me
09-21-2006 18:07:56
How do we find out about this? We need more info.
John179
09-21-2006 15:54:16
Now that you have this thechnology how aggressive do you plan on marketing. I would be interested in info and if any mods have to be done to housing.
Thetractorshop
09-21-2006 18:28:36
 Re: John Deere pullers rejoice! in reply to John179, 09-21-2006 15:54:16
Available next month for full swing production. The first one was built for a JD B, at this time, all I will say is that it goes inbetween the bullgears, all that has to be done to adapt this kit is machine some material off of the bullgear to make room for the adapter hubs, they slide on the axle before you reinstall the large nut. it then has a main case that fits over both hubs. fully adjustable! we do need the JD A and G axle spline pattern where the bullgears attach to the axle to be able to make them for the A's and G's. If anyone has a junk A and G axle they would care to get rid of,, I just need the bullgear side of the axles, enough to remake the spline for the hubs. The A and G kit is larger in size VS what the B is,, but all fits the same.
Drew
09-21-2006 15:47:34
I would like more information, how do I contact you?
