cam degree wheel
jdjack
09-19-2006 19:30:01
Was looking at buy a cam degree wheel. Will be using it mainly on JD two cylinders.
What do some of you guys use, and what do you suggest?
Thanks Jack
John Dear
09-19-2006 20:15:24
 Re: cam degree wheel in reply to jdjack, 09-19-2006 19:30:01
The larger the diameter the better. There is so much dwell time top and bottom on a two banger that a larger wheel will sure help with accuracy. You will need dial indicator or home made piston stop also.
