TRACTOR PULL .SPRINGFIELD,TN -9/23
red brand
09-19-2006 19:08:33
ANTIQUE TRACTOR PULL TO BE HELD AT ROBERTSON CO.FAIRGROUNDS(WEATHER PERMITTING)SATURDAY 9/23.PULL STARTS AT 1:00 PM.FARMSTOCK,OPEN AND OUTLAW CLASSES.. THERE WILL BE 3 KING OF THE HILL CLASSES:(6440 LBS FARMSTOCK(NO CUT TIRES)..(4250 LBS 1ST GEAR 4 MPH.(CAN RUN CUT TIRES)..(6140 LBS 1ST GEAR 4 MPH.(CAN RUN CUT TIRES)EACH KOH CLASS PAYS $100.00 FOR 1ST PLACE ONLY..FOR MORE INFO CONTACT CHARLIE COOK=615-714-6651 OR TYRELL JACKSON=615-578-4143..HOPE TO SEE YOU THERE!!!
Josh Caplinger
09-21-2006 07:12:54
 Re: TRACTOR PULL .SPRINGFIELD,TN -9/23 in reply to red brand, 09-19-2006 19:08:33
what rules you run for the open and outlaw? You have a tire size lemet? Will you allow any kind of cuts?
red brand
09-21-2006 17:24:31
 Re: TRACTOR PULL .SPRINGFIELD,TN -9/23 in reply to Josh Caplinger, 09-21-2006 07:12:54
TIRES..RULES STATE THAT OPEN AND OUTLAW CLASSES CAN RUN UP TO A 18.4 TIRE(CUT OR NOT) ON A RIM NO WIDER THAN 18 INCHES..AS FAR AS THE RPM..OPEN CLASS IS 20% OVER STOCK AND 6 MPH..OUTLAW CLASS IS ANY GEAR ANY RPM...HOPE THIS HELPS
Josh Caplinger
09-21-2006 17:27:45
 Re: TRACTOR PULL .SPRINGFIELD,TN -9/23 in reply to red brand, 09-21-2006 17:24:31
will you alow any kind of cuts on the tires? Like V-cuts or double cuts?
