Roosa Master pump
Low Budget
09-19-2006 08:44:19
I have a JD 5020 that I recently added a turbo to. It burns very clean even with the fuel screw turned all the way. Is there a easy/cheap way to get a little more fuel to the engine with the stock pump?
Oliverdiesel
09-23-2006 08:18:45
 Re: Roosa Master pump in reply to Low Budget, 09-19-2006 08:44:19
leaf springs are available, also the external torque screw (if equiped) can limit the metering valve, this can allow you to fine tune the fuel delivery.
ihcpuller
09-19-2006 16:29:28
Take the pump to a pump shop and have them replace the leaf spring on the head where you set fuel with one of a higher number and remove all the shims from under the old leaf spring , this will give you a much larger range of fuel and should make your deere come alive.
Low Budget
09-19-2006 18:16:29
 Re: Roosa Master pump in reply to ihcpuller, 09-19-2006 16:29:28
Thanks, I wondered if there were different leaf springs available
pdi man
09-20-2006 19:48:29
 Re: Roosa Master pump in reply to Low Budget, 09-19-2006 18:16:29
I need you to e-mail me. In the middle of doing the same thing for a working application, and was wondering what you did and how you did it. Want to make sure I am on the right track.
pdi man
09-20-2006 19:50:26
 Re: Roosa Master pump in reply to pdi man, 09-20-2006 19:48:29
Sorry about that, got trigger-happy and forgot to post the addy. [email protected]
