Masseyharris 55 HP
need power
09-17-2006 19:09:27
looking for a good machine shop or someone that knows what to do to a mh 55 head to get some more hp.have stock bore,turning about 20% over rpm.
MH49
09-19-2006 15:32:13
 Re: Masseyharris 55 HP in reply to need power, 09-17-2006 19:09:27
I am not sure on the 55s but on the 44s there is no such thing as a propane head. They increased the compression with the pistons. Propane maninfold will help though. I agree with the other folks however that a little clean-up here and there with a die grinder will do wonders at 20% over rpm.
steve from mo - dangit!
09-18-2006 07:14:40
 Simple stuff. in reply to need power, 09-17-2006 19:09:27
Like he says, start with the LP head. Then have the valves ground and the ports cleaned up. At 20% over stock RPM, you don't need/can't use much more.
Ian Johnsen
09-17-2006 21:22:52
Find a head from an LP model. They have smaller cumbustion chambers for higher compression.
