Supercharger on 460
VTMATT 460
09-16-2006 08:03:33
I am looking to go "hot farm" with my farmall 460. What i can put on it for a carb and supercharger? Make and models will help tremendously. And any advice from past experiences!!
thx,
ms
Turbos10
09-17-2006 10:04:16
 Re: Supercharger on 460 in reply to VTMATT 460, 09-16-2006 08:03:33
I have a Holley 350cfm 2bbl carb with a Garrett T3 blowing through it. The turbo is from a Chrysler Labaron, and I also run an intercooler from an 86 Turbocoupe.
A Turbocoupe T3 turbo would be well suited for the additional cubes of the 460. RPM is also a consideration. The T3 should be good for 3-3500RPM depending on boost levels. It also has an integrated wastegate which will make it somewhat simpler to setup.
If you are planning to spin it higher you will need a larger compressor. I would suggest a T4 compressor in the 45lb range with a .63 A/R T3 Turbine. Any turbo shop can fix you up with a hybred like this. You will need a 35mm external wastegate to make a setup like this work well.
Of course a custome manifold will be needed either way. You can see pics of mine in the picture section of this site.
Chris
ohio
09-16-2006 09:54:19
how about a setup off of a buick grand national 3.8?
2 words
09-16-2006 09:37:24
fuel injection
supercharged
09-16-2006 08:49:42
you're much better off to go with a turbocharger.
