JD A bore limit?
Dairy Farmer
09-15-2006 18:17:14
i'm looking at boreing out my JD A for pulling and was wondering how much i could go before weakening the water jacket too much. This is an early styled A that is a hand start but i'm not worried about starting it as long as i have a chain and a vehicle around. thanks in advance! DF
Rusty Junk TX
09-18-2006 03:49:00
 Re: JD A bore limit? in reply to Dairy Farmer, 09-15-2006 18:17:14
For aircraft pistons:
Chester Roberts Supply
Collinsville, TX (DFW metroplex area I believe)
903-429-6805 or 903-429-6656
Marcus
R James B
09-15-2006 20:59:30
I have a 5.75 bore which is .250 over with a 9inch stroke. The thing I like about .250 is a set of 5.75 inch airplane pistons are easy to find and you can resleeve it easy enough.I have known some people to go a little bigger but had heck of a time trying to get it to seal.
Lynard
09-15-2006 18:35:53
Dairy Farmer I pull an unstyled A that is bored to 5.875 which is .375 over stock. Pulled it for 8 years and still going. 8.375 stroke and 9.5:1 compression and hand crank it. Lynn
JDGnut
09-15-2006 20:49:14
 Re: JD A bore limit? in reply to Lynard, 09-15-2006 18:35:53
5.875 will depend on your block... some will hold some won"t... depends on the casting.. and how rusted the water jacket is.. You can use the 70 pistons with a stroke or longer rods.. Many just stick with 5.75... Good Luck..
JDGnut
JDMark
09-16-2006 15:52:25
 Re: JD A bore limit? in reply to JDGnut, 09-15-2006 20:49:14
For a 5.75" bore Alan Schooler uses a Pratt + Whitney aircraft piston, but you need to have a different rod made becouse the pin height is different on the aircraft pistons. Good Luck JDMark
question
09-19-2006 16:38:23
 Re: JD A bore limit? in reply to JDMark, 09-16-2006 15:52:25
Mark, does Alan Schooler do ANY work, or does he just farm it out and mark it up?
JDGnut
09-16-2006 20:32:00
Not sure what he is charging for the pistons.. but you can purchase them new or used from a company in Dallas.. (5.75- stock block or 6.1 powerblock) Too bad I cann't remmeber the name of the company.... JDGnut
JDMark
09-17-2006 03:52:01
 Re: JD A bore limit? in reply to JDGnut, 09-16-2006 20:32:00
I think your talking about J.T.Luckey in Dallas, Texas #214-357-9331 ask for gary in parts. JDMark
AC
09-19-2006 14:51:40
 Re: JD A bore limit? in reply to JDMark, 09-17-2006 03:52:01
whats the CD on the 5.75 Pratt pistons? what about the pin size? thanks
Drew
09-19-2006 15:15:28
 Re: JD A bore limit? in reply to AC, 09-19-2006 14:51:40
The ones I have seen are 2.705 CD and 1.372 wrist pin.
If you are going to use airplane pistons, get the pistons and measure them before you bore the block. They have a lot of clearence built on them and you may want to adjust final bore size accordingly.
