JD B STROKE
lisa m
09-14-2006 18:19:00
I have a 5.25 inch bore and I am looking for 55 to 60 hp. How much stroke do I need. Help and comments would be appreciated.
jd b puller
09-17-2006 14:20:45
 Re: JD B STROKE in reply to lisa m, 09-14-2006 18:19:00
Keep your Journals big, in case you want to go bigger on bore. There's a lot of 7.5" x 2.25" journals out there but easy to break.
Suggest the following:
7.625 stroke
2.625 rod journal
330 cubic inches
Waukesha rod - not sure which one, but Keith knows.
Call Keith Merfeld and tell him these specs.
563-582-8710
I'll help
09-15-2006 06:38:30
Are you looking for longevity or HP?
How much work do you want to do to get it in there? Gimme a call.
919-605-6040
L M
09-14-2006 20:20:30
Already have an A. Just trying to build a B and seeing what combo works and fits to be in that hp range.
TS
09-14-2006 18:42:56
Get an A
JOE ZIP
09-16-2006 04:51:51
 Re: JD B STROKE in reply to TS, 09-14-2006 18:42:56
You know there"s a time when just saying nothing is better and you don"t prove your ignorance
