NEED 450 CARB
MIRACLE CHILD
09-11-2006 16:47:54
LOOKING FOR A 450 CARB FOR MY M OR A BIG CARB THAT WILL FIT ON THAT MANIFOLD
ChadS
09-12-2006 08:00:29
 Re: NEED 450 CARB in reply to MIRACLE CHILD, 09-11-2006 16:47:54
Use a M carb. 6 cyl carb bowl. #27 venturi will make highest torque at lower rpms, a 29 will help run the higher rpm, and not lose so much low end torque. If you go bigger on the engine you have,, it will drop the lugging power, not increase it. If your running race fuel, go back to pump gas 89 minimum. Race fuel, hurts low end torque in stock stroke, close to stock compression ratios in farmalls. When you run a compression test,, if its under 150 psi,, All the exotic fuels, big carbs, big manifolds, is not helping even at 281 ci. So keep it as stock on the intake, and carb, and fuel, and make due with that, it would run stronger,, If the compression is over 150,, but not over 170, you have room to increase the venturi size from a 27, up to a 29, that allows more air in, and change the jet size to match, and see some better results on the HP increases. at 170psi,, you will need a mimunum of 89 octane, maybe a 90 octane if it pings on 87 or less. Still keeping a stock, or new intake, can do the trick just fine. at 150 psi,, should be in the low to mid 60's in hp out of 281,, with a 27 venturi and 89 pump gas. If you want help, lets dig a little deeper in what your engine is now,, and then build it from there,, there are alot of things you can do and not spend alot of money,, you have a good engine I belive,, it sounds like it needs more compression. Im guessing its in the 130 - 140 psi range to make only 55 hp. Info neede to know would be, venturi size,, fuel type, and compression pressure at cranking speed. Take all 4 spark plugs out, open the throttle all the way, and crank the engine over till the guage quits building pressure, record the readings, and post back if you wish,, options on what you can do is imperative on that information. ChadS
MIRACLE CHILD
09-14-2006 17:05:57
 Re: NEED 450 CARB in reply to ChadS, 09-12-2006 08:00:29
CHAD SOUNDS LIKE U BEEN DOING THIS FOR AWHILE IS THERE A PHONE I CAN CALL U ON TO GET MORE FROM YOU
ChadS
09-14-2006 20:06:29
 Re: NEED 450 CARB in reply to MIRACLE CHILD, 09-14-2006 17:05:57
574-893-7437 is the shop phone. ChadS
TWL
09-11-2006 18:20:50
I have one,it's rusty but may clean up
MJF
09-11-2006 18:05:28
400 and 450 has the same carb, if that helps any
