What injectors for 4-53 detroit in oliver 1950?
SupC
09-09-2006 18:13:29
This tractor will be pulling in 9500 and 10500 farm stock. Would like to get more fuel, but don't want to get more than it can get air for and get out. What would be a good size injector to use , hadn't pulled the valve cover off yet, but figure it has 45's in it. Or would it be better to get some work done to these injectors?
1206SWMO
09-10-2006 08:14:25
 Re: What injectors for 4-53 detroit in oliver 1950 in reply to SupC, 09-09-2006 18:13:29
I'm running 70's in mine.It lets me run 3rd gear in the 13,200 and 14,000 lb farm stock classes.I have 18.4x38's.I used to only be able to run 2nd gear so got a good hp increase.I turn it 3000 rpms.
JDH
09-10-2006 11:11:21
 Re: What injectors for 4-53 detroit in oliver 1950 in reply to 1206SWMO, 09-10-2006 08:14:25
Hey 1206 SWMO, How did you do your hitch I am down to Hitch and Wheelie bars now. Thanks,
1206SWMO
09-12-2006 18:59:18
 Re: What injectors for 4-53 detroit in oliver 1950 in reply to JDH, 09-10-2006 11:11:21
I took the regular drawbar off.I got a piece of steel 3/4" thick,6" wide,and 12" long.I bolted it to the bottom of the wishbone and cut a 3" hole in it 2" back of the wishbone.Its 20" high and has worked good so far.
I dont run any weight on the front end.Balance is perfect in 13,200 and 14,000 stock classes with cut 18.4x38's.We dont have to have tip over bars.
I'd love to take it down to 8000 lbs but dont think I could get the nose light enough without getting rid of the cast tub.
Theres a 2255 V-8 pulling the 6000 lb class in my area.
wk4036
09-10-2006 05:25:27
"Ole Bob" is pretty partial to the 9G90 injectors, he had them in a 3-53 in a Thomsom High Crop and it ran pretty sweet as did my 2-71 in my Thomson but he changed them to something else and it doesn't run as nice as before. I also changed mine to 130 injectors and it doesn't run as nice as the 9G90's. The 9G90 will let you put on a pretty good smoke show for the crowd also. You need to get rid of all the air restrictions possible, I had a LA Case with a 4-71 and I mounted the air filter right to the blower with a self built "OH SH!!" flapper inside in case it ran away.
LW
09-09-2006 19:04:23
YOu need to talk to Bob Evans he's near Kalamazoo ,MI, He was the research/delopment man at DD, for years, he Can put you on the right track,Don't have his # shouldn't be to hard to find.
