Question for Turbos10 ?
Ohio Puller
09-09-2006 16:32:01
I saw pictures of your turbo M in the past forums and I was wondering if you have pulled it and how it's working for you ?
Turbos10
09-11-2006 19:14:15
 Re: Question for Turbos10 ? in reply to Ohio Puller, 09-09-2006 16:32:01
Short anwser....it is running good, but I have not got it pulling too good yet.
I went to the first pull since I got the front end changed up. Ended up taking 300lb off the front end with the swap which will make weight transfer alot better.
The problem I have now is that I can not even come close to getting the power to the ground. I think on a REAL good track with my 15.5's I may can load the engine in 4th gear. The last two tracks have not been real good and I could barely load the engine enough to get it off the rev limiter.
I plan on going to 18.4's as soon as I find a reasonable set close to home. I expect after that I should have an easier time getting power to the ground.
