QUESTION FOR CHAD
JMS1066
09-07-2006 07:06:51
i have found a super m propane head cast numbers 8574dcx i know it is not as good as a 450 propane but will it help on my farmall m or am i wasting time thanks
ChadS
09-07-2006 08:09:42
 Re: QUESTION FOR CHAD in reply to JMS1066, 09-07-2006 07:06:51
In the parts book, they list the 8574 head as a gas/LP head for the Super M. Basicly a recast of the 8060 head. Same chamber, same valves. The 450 gas head is the better version, then the LP head as the best. Dependion on what you do with this tractor, if it will see farm work, Id go with the 450 gasser head, then you may still run a pump grade fuel, with the LP head, it will have to use higher octane fuels. Chad
JMS1066
09-07-2006 12:33:13
 Re: QUESTION FOR CHAD in reply to ChadS, 09-07-2006 08:09:42
ALL I USE THE TRACTOR FOR IS PULLING. WHAT ELSE WOULD BE SUM GOOD IMPROVMENTS. THANKS JOHN
ChadS
09-07-2006 15:09:39
 Re: QUESTION FOR CHAD in reply to JMS1066, 09-07-2006 12:33:13
All the little things,,, good ign, rebuild the distributor advance under the points plate, replace the heavy stock tension springs with lighter ones, that helps throttle responce. Electronic ignition, with a good coil. I like Accel super stock coils. Cheap, and they will Zap you hard enough to,, well, its a hot spark!!! Stiffer governor spring is a must,, the governor has to be able to go beyond its stock settings, then tune it back to the rpm you need. The spring tension holds the governor more steady, and the problem with trying to get more rpms out of the stock governor is no longer a problem! It also helps throttle responce greatly, so with the distributor, and the governor working faster, the better the engine can accelerate. Then comes carb work,, that depends on Cubic inches, rpm, fuel type, compression pressure, and possibly the add on's like aftermarket manifolds, different head castings,, etc etc. Its a little more detailed information, but so easy to do yourself,, and get great results. Fuel flow is critical, so make sure the fuel can flow freely from the tank to the carb bowl. Make sure the gas cap vent is open, otherwise the tank could vaccum lock and hold the fuel in the tank till the cap is loosened. Not a real preformance gain there, but its good to check out. Fuel type is critcal, especially in a high compression engine. There is fuel that fire the engine and run, and there is fuel that does that and more, so dont be fooled by the smell out the exhaust,, especially if pump gas can do better. Ive seen alot of tractors come in running 110, and have less power than what a good premium gas can offer. But that comes down to compression,,, over 180 psi at cranking speed. Chad
