JD 60 Head on a JD A
Hooked
09-06-2006 05:45:29
I was told recently that a JD 60 head would fit on a JD A. Is that any A or does it have to be one of the late A's with head casting #4226?
Thanks for your help.
a puller number 1 eh
09-13-2006 15:17:58
 Re: JD 60 Head on a JD A in reply to Hooked, 09-06-2006 05:45:29
yes, a 60 head will bolt right on to ANY styled A motor. a little grindin on head and frame rails on cast frames...and a notching out for pressed steel frames. they feed ok, look at a JD 60 hp compared to a late A, same block back, different head up assembly..... and o ya....an A with a 620 engine bolted in it will run ya about 50hp.
Hooked
09-07-2006 13:04:46
Thanks for the response - will the 60 head also fit a #2 JD powerblock? I assume the only difference is the size of the bore.
Mike n Mo
09-06-2006 17:30:51
I recall someone mentioning once that there are clearance problems between the frame and 60 head on an A with a pressed steel frame, but I don't know from personal experince as I have never tried it. I do know it will bolt onto the block with no problems. An early styled A will work with no problems. Maybe someone will chime in as far as the late A frame clearance issue that knows for sure. Mike
Drew
09-06-2006 05:58:29
A 60 head will bolt to any styled A, SN: 488000+
oskpuller65
09-06-2006 07:03:45
 Re: JD 60 Head on a JD A in reply to Drew, 09-06-2006 05:58:29
i wounder how much more cfm the 60 head will feed a stock A jd
