its time for pulling association to lift ban on me
mlpankey
08-29-2006 03:24:27
methanol is an agricultural by product that use of would increase corn sells . methanol has a lower btu rating than 110 so you burn twice as much . but aa 1.60 a gallon its still cheaper than 110. unless the engine is 15:1 on compression it really doesnt make any more power .engine temps do run cooler and sometimes that can increase power but if everyone runs it ten the playing field is level . im tired of paying 5.00 to 10.00 dollars a gallon for 110 gas. any thoughts and maybe someone will listen and lift the bans.
dave metzger (hustler pu
09-01-2006 18:54:27
 Re: its time for pulling association to lift ban o in reply to mlpankey , 08-29-2006 03:24:27
alcohol,,,,ah yes home grown and hillbilly aproved is my motto well at least we have some people who know the difference between wood and grain we run grain or ethanol,, there is a power difference and a good one, we run it in our modd and in our 1939 farmall A it runs real goodddd all origional stock motor parts even flat top pistons no head work no nothing real simple now i have been working with hooch sence oh bout 1983 some where any way there are some secrets with alcohol all you need is to ask we also work with Saginaw Vally State Unifersty in michigan in the alternative fuel department go figuar not bad for an farm boy any way there is lots going on with this fuel and biodesel we r kicking but with that also so lift the ban kick it loose and have some fun we do,, we pull and belong in the EMTPA in michigan got any questions ????? ?????
mlpankey
08-30-2006 14:40:49
jim i still dont get the money issue 1.60 a gallon for methanol is cheaper than 5.00 a gallon for cam 2 .oops my third grader figured that simple math promblem
Gary from Muleshoe
08-29-2006 21:27:29
Jim I believe that man is trying despartely not to appear ignorant. Oops to late for that!!!!!
mlpankey
08-29-2006 21:18:43
no stupid theconversation is replys on the topic not with myself. 1.60 is more affordable than 5.00
Gary from Muleshoe
08-29-2006 16:15:41
I will never understand why some people want to take a good sport and turn it into something we can't afford to do, or to make difficult for those that can barely afford to pull stock. Just a thought. Keep alcohol out all togehter "all kinds."
mlpankey
08-29-2006 15:41:02
nitro is miexd at a pecentage with methanol .typically atrue reading is at 68 degrees in temp. and decreases as temp goes up.typicaly 100 percent nitro at 90 degrees temp will show 94 percent by volume. and according to my friends who use nitro 100 percent nitro will double the horsepower output over gas or methanol. but that you have to really keep the engine rich and usually rebuild it after every pass.also at 40.00 a gallon doesnt make it cheaper to run .also it is easier to detect exotic mixtures in methanol cause when mixed with water it usually turns the mixture red in color.
Jim Johnson
08-29-2006 19:12:18
 Re: its time for pulling association to lift ban o in reply to mlpankey , 08-29-2006 15:41:02
What are you doing, having a (stupid) conversation with yourself.
mlpankey
08-29-2006 15:25:30
yeah a catylist like toulene. i agree that nitro is very dangerous for exploding engines but im not talking about using nitro by percentage .but was talking about methanol even though i got cofussed on what it was made from. i will also agree that if the motor has 15:1 compression and a fuel delevery syaytem capable of 14psi that it will make more power than gas. but in antique tractors with carbs that the floats want handle more than 2 psi there will be no significant increase in performance
Jim Johnson
08-29-2006 09:27:22
In my opinion you are wrong. Just do not believe antique tractor pulling is ready for alcohol as a fuel. Too dangerous. We find it volatile enough in the form it is used now at pulls (LOL) but we don't get people hurt. Talk about putting an end to a lot of fun just have one of those detonations, get a bunch of people hurt or worse, and you wouldn't be able to get insurance to have a pull. Let's just have fun doing what we already barely can afford. If you have the money there are places you can go do this. Just my opinion.
skip 33652
08-29-2006 05:29:10
methanol is wood alchohol so it wont help sell any more corn. ethanol is corn liquor or white lightning.alcohol burns with an almost invisible flame especially when out in sunlight so there is some aditional risk. Paul
Drew
08-29-2006 05:18:12
Ethanol is made from corn, methanol is made from wood, not corn. And then you can have a problem when someone that doesnt know what they are doing tries to run it. Alcohol engines are very touchy to weather conditions, and it would be only a matter of time before someone ran one way lean and detonates one.
The rest of the story
08-29-2006 14:39:53
 Re: its time for pulling association to lift ban o in reply to Drew, 08-29-2006 05:18:12
Methanol makes 20% more hp. than gasoline. It burns cleaner and cooler than gas. I have ran methanol in open rpm antiques and in my super stock tractor for the past 15years. I hear people talk about how dangerous it is becase you can't see it burn, but as with gas, if it is used responisibly you will not have any problems. Methanol also mixes well with nitrometane :). Where you are wrong is it being cheaper. It does cost less per gallon, but it takes twice as much methanol to make the same power as gas. That is the reason you have to double the jets in a carb to get it ot run on methanol. Hope this helpd Fuel the debate. Oh, nitro also mixes with gas by using a cataylist. :)
PGpower
08-30-2006 10:32:43
 Re: its time for pulling association to lift ban o in reply to The rest of the story, 08-29-2006 14:39:53
There is a ton of info about Ethonal on www.e85fuel.com I includes techinacal information, FAQ, and so on. I am not saying it is 'right' for antique tractor pulling, but there are a lot of 'myths' about it.
Below are two FAQs for the website.
Is E85 more toxic or dangerous than gasoline?
Response:
No. 100% ethanol can be and is ingested by human beings. The fuel ethanol must be "denatured" with gasoline or a bitter agent to prevent ingestion. Also, ethanol does not contain the harmful carcinogens and toxins found in gasoline. If E85 is spilled on the ground, can it contaminate ground water?
Response:
Ethanol is water soluble, non-toxic and biodegradable. E85 contains roughly 80% less of the potential contaminants found in gasoline.
