Remus, MI truck rules
superih
08-28-2006 08:32:21
Central Michigan Performance Diesel Presents
Remus Truck Pulls
$20.00 a Hook % Payback Contact: Adam Cornell: 989-621-9806 Remus Sept 1st Weigh in 5-7 Kevin Chaffee: 989-560-1457
Street Diesel Truck Rules
� 7000 & 8000 lb classes. Trucks must have stock appearance. Must have upholstered interior. Factory mounted fuel tanks and batteries � One Power adder allowed: Injectors, Chip, Cam Pate, Computer Box, Turbo, etc. (air intake, exhaust not considered power adders.) Stacked Chips not allowed in this class.
� Truck smoke limited to �GREY� haze. Black smoke automatically moves truck up to modified diesel. (determined by tech)
� Stock appearing injection pump required.
� Mechanical or electronic fuel injection permitted.
� Maximum wheelbase permitted 158 inches.
� Maximum engine size: 460 cubic inches. Engine must be factory in one ton or smaller pickup truck. Engine must remain in stock location as intended by manufacturer.
� Hook point must be no closer than 48 inch of centerline of rear axle, hitch height maximum of 26 inches, minimum of 3 inch opening, must extend beyond the rear of the truck. No �trick� type hitches permitted. Hitch must be stationary in all directions.
� Must have D.O.T. approved tires. No studded tires or chains. No bar or terra tires. Dual rear wheels permitted.
� Front weights must be no more than 60� from the center line of the front axle to forward most point and be securely fastened. � Only OEM transmissions and transfer cases permitted. � All differentials must be OEM from one ton or smaller pickup truck and have working brakes on all axles.
� Rear suspension must have a minimum of 1 inch of travel. � Air bags must be soft, Judge able to push in with a finger
� Traction and ladder bars allowed. Drive shaft loops recommended � Exhaust must exit straight up or down or have two 3/8� inch bolts mounted in cross pattern.
� Driver must have proof of insurance and registration. Trucks may be trailered to event.
� Track and tech officials� decisions are final. (trucks will be teched if questionable)
Modified Diesel
� 7000 & 8000 lb classes. � Must meet Street Diesel rules.
� All Power Adders allowed: Injectors, Stacked Boxes, Chips, any Turbo Configuration, Nitrous, and Propane.
Gas Truck
� 6000 and 7000 lb classes. Must meet all pertaining diesel rules.
