3020 turbo
slowride
08-27-2006 19:06:34
how could a fellow put a turbo on a 3020 with the stock hood? will it fit, or do i have to make it a little ugly?I know it can be done, I just want it to look good.
slowride>
digger44
08-30-2006 07:09:32
 Re: 3020 turbo in reply to slowride, 08-27-2006 19:06:34
I have seen a turbo set up on a 2520 the manifolds came off some kind of industrial motor. like in a 550 dozer or something like that it had the original hood.
ajdeereman
08-28-2006 19:11:54
The M&W kit will fit under the hood but you have to cut a hole in the hood for the stack and it has a plate to put in place of the factory muffler
JDBert
08-29-2006 07:34:32
 Re: 3020 turbo in reply to ajdeereman, 08-28-2006 19:11:54
Did they change that on the 3010/20 manifold like they did on the 4010/20 manifold? The early ones for the 4010/20 were a one piece manifold that you cut the hood- they were proan to cracking and later they had a 2 piece manifold that came out the muffler hole.
JDBert
08-28-2006 07:09:24
Slowride-
M&W made a kit for the 3020 just like they did for the 4020's a little harder to find though-
Jeff Oliver
08-27-2006 19:50:34
Not sure how it is done but it should be able to be done as there were alot of 4020's that had turbos added to them without altering the hoods.
