Finished wide front and tilt hood on my turbo M.
Turbos10
08-26-2006 12:50:06
Link
Link
Thought you guys might like to see what I have done. Hope the links work....
Mperfection
08-27-2006 17:12:11
 Re: Finished wide front and tilt hood on my turbo in reply to Turbos10, 08-26-2006 12:50:06
I have the same turbo on my M but i cannot make any boost at stock RPM. I currently am using the stock manifold and blowing thru the original carb. I just throw the turbo on for s(*$ and giggles to show off but i am not getting any real HP. Sounds bad a&* though!!!
Turbos10
08-28-2006 17:36:25
 Re: Finished wide front and tilt hood on my turbo in reply to Mperfection, 08-27-2006 17:12:11
My engine makes boost very easily but not at factory RPM. The factory manifold is a terrible design, but I would think it would still make boost.
I test my tractor in road gear and can make boost starting around 16-1800 RPM. However, the only real way to test it is hooked to the sled since it hits the rev limiter in about 1 second in road gear...kindof fun accelerating like a car on a 50 year old tractor:).
POORDIRT FARMER
08-27-2006 15:22:11
HEY TURBO10, LUV TO SEE STUFF LIKE THIS , WHAT KIND OF CHARGER ARE YOU USING? HOW MANY RPM'S DO YOU EXPECT TO TURN? I NEW A GUY THAT PUT A 301 6 CYLINDER IN A M CHASSIS, WITH A SMALL CHARGER AND A HOLLEY FOUR BARREL. LUV TO SEE MORE PHOTOS.
Turbos10
08-28-2006 17:29:30
 Re: Finished wide front and tilt hood on my turbo in reply to POORDIRT FARMER , 08-27-2006 15:22:11
I am using a small Garrett T3, 50 trim compressor and .48 A/R turbine. It works very well with the small cubes and I have room to grow to a larger T3/T4 combo as time goes on. I have had thoughts of the 301 and a similiar setup to mine. It would have alot of power potential and is a little better engine design from what I have read. I will run the little 4 till I get bored or it craters. I run 2100RPM right now and can not get the power to the ground. I would like to run 3-4k but I have to get a flywheel and girdle on the ole girl first.
voager212
08-26-2006 15:53:22
can you get some pics of the super charger and is it like it a kit or did you make it costomly fit
Turbs10
08-26-2006 20:32:21
 Re: Finished wide front and tilt hood on my turbo in reply to voager212, 08-26-2006 15:53:22
Link
I thought I put a pic up a while back, but I could not find it.
Anyhow, I built everything from scratch. I have tinkered with turbo stuff so I decided to give it a try on the M. It worked very nicely after getting alot of bugs worked out. Last pull I went to I could not get a bite could barely load the engine in 4th. I think on a good track it will work well.
JDGnut
08-26-2006 20:21:25
Looking good.. I like the hood.. haha..
Its turbo charged...
JDGnut
grin
08-27-2006 19:14:55
 Re: Finished wide front and tilt hood on my turbo in reply to JDGnut, 08-26-2006 20:21:25
FYI: If you want to get technical, a turbo is a type of supercharger. Have a good one.
Turbos10
08-26-2006 20:35:32
Yeah....I know this guy with a JD that helped me along alot :).
Now if I can just get the damned steering finished....I am ready to go pulling.
You coming to Cisco? I will be there for sure.
colekicker
08-27-2006 23:03:51
 Re: Finished wide front and tilt hood on my turbo in reply to Turbos10, 08-26-2006 20:35:32
Can you post a pic of how you rigged up the tilt hood. JDGnut's hood is awesome, and I have had similar thoughts in my head.
Turbos10
08-28-2006 18:06:29
 Re: Finished wide front and tilt hood on my turbo in reply to colekicker, 08-27-2006 23:03:51
I used the 1/2 inch tube to built a frame that holds together the grille and hood. I also did some body work and alignment to get the grille/hood parting line as perfect as I could. Then I tacked it in place before building the frame. The frame is welded directly to the hood/grille. The hinge is some various pipe I had laying around.
My original plan was to have it completely lift off with no pins so I keyed the hinge pin that you see attaching to the frame. I found that the off center hinge made the hood want to rotate sideways when lifted and the lift off design made it so the assist cylinder actually pushed it right out of the frame.....so I drilled it and put a bolt through as a pin to hold it steady.
Link
The picture is better if you can see it full size. For some reason when I post here the pictures shrink??
GPULLER
08-29-2006 08:26:30
 Re: Finished wide front and tilt hood on my turbo in reply to Turbos10, 08-28-2006 18:06:29
Why paint the tractor? The "JD Guy" who helped you with the hood hasn't painted his yet! LOL
JDGnut
08-29-2006 11:27:13
 Re: Finished wide front and tilt hood on my turbo in reply to GPULLER, 08-29-2006 08:26:30
Bah.. Bahh Bahh... GPuller.. are you speaking???? haha... I really wanted my G to have a front tilt hood.. but it was easier to make it tilt from the back... All I help him do was open the G hood once.. Next thing I know he's posting pics of his M... Paint is over rated... (Too bad I'll have to sandblast the hood now... ) I'm going to be in MN and IA about the 16-18th (I think those are the dates..) I'm headed to the Clay County Fair to watch the Outlaws pull on Sunday.... JDGnut
Turbos10
08-29-2006 18:16:48
 Re: Finished wide front and tilt hood on my turbo in reply to JDGnut, 08-29-2006 11:27:13
Well, don't forget the info on the steering box....
That was a big help. It is going to work great with the porshe rack and pinion. The old porshes had the rack straight in the middle of the rack so it works great on the tractor.
JDGnut
08-30-2006 10:52:15
 Re: Finished wide front and tilt hood on my turbo in reply to Turbos10, 08-29-2006 18:16:48
Hhmm.... how hard was that to find... going to be need aonther one.. or two...
JDGnut
08-27-2006 22:11:15
Not sure.. I've got to be in Waterloo for a week coming up.. and going to sneek off for the weekend and go to the Clay County Fair in Spencer, IA... Outlaw Truck and Tractor Pull.. JDGnut
