TUNICA
IH 501
08-26-2006 11:29:18
Will the 501 Red Diamond Engines be allowed to pull this year?
Open Range
01-15-2007 20:26:01
 Re: TUNICA in reply to IH 501, 08-26-2006 11:29:18
I know that Tunica is over with,but I think there should be no problem with the RD engine.The RD was a Internalional Harvester engine,witch came in power units & trucks.Where I pull at a lot of olivers use (320 ci) engines(not 310s) witch came in (power units,road rollers,cranes)not tractors.Big difference in heads.The molines use 800hd parts,witch was a power unit engine,and if they did come in a tractor, I bet I could eat all that did.If the rules say stock appearance,other than being longer they (221,301)are similar.Most (oliver,moline)pullers are against the RD,because of competition in light classes.If heavy classes are what you want to pull, you need a (case,john deer,moline,w-9 international)because even as big as the RD is it can't compete with the big cubic inches,unless in outlaw classes(high winders).I'm currently building a RD myself,and hope to be competitive up to 5250lbs 6&8mph.All these people that are against the RD need to understand this sport is for fun,and if I don't win every time,no big deal.Just up there close with the (top dollar rides)is close enought for me.
Intrested
08-27-2006 11:25:41
Rule states "All parts must be of tractor origin"
This is truck origin I believe.
supermpuller
08-27-2006 12:11:00
 Re: TUNICA in reply to Intrested, 08-27-2006 11:25:41
The 460 is a truck motor too, you gonna DQ a stock 460?
Lamont
08-27-2006 13:54:47
 Re: TUNICA in reply to supermpuller, 08-27-2006 12:11:00
If it's a stock 460, wouldn't that make it "OF TRACTOR ORIGIN?"
Lamont
08-26-2006 20:06:52
Is that within the rules?
NOT INTERESTED
08-28-2006 05:33:37
 Re: TUNICA in reply to Lamont, 08-26-2006 20:06:52
HOW ABOUT BIG MOLINE MOTORS THEY DIDN'T COME IN GVI TRACTORS OR AIR PLANE CARB
iNTRESTED
08-28-2006 08:10:09
 Re: TUNICA in reply to NOT INTERESTED, 08-28-2006 05:33:37
How did we get away from the Red Diamond question?
I would say yes.
08-28-2006 11:38:27
 Re: TUNICA in reply to iNTRESTED, 08-28-2006 08:10:09
Brockmire's have one in a 460 and I'm sure it will be there. The 800HD's were available in a tractor.. But I have taken rd501's out of power units and grain trucks, so I would think that world qualify as ag use. A red diamond engine was also offered as a replacement engine for WK-40's. So there is the tractopr origin connection. I'm sure no one will complain until you win.
Spotter
08-28-2006 13:48:21
 Re: TUNICA in reply to I would say yes., 08-28-2006 11:38:27
They have been allowed every year at Tunica and there has been no change in that status...Spotter
what about
08-28-2006 15:52:33
 Re: TUNICA in reply to Spotter, 08-28-2006 13:48:21
Ok, so if you try really hard you can kinda make the connection to an ag motor. Don't know nuthin bout no red tractors, assuming same number of cylinders. What about the RPM's, are they that of the engine or the tractor frame that it's in?
Spotter
08-28-2006 16:28:47
 Re: TUNICA in reply to what about, 08-28-2006 15:52:33
RPM based on make and model of tractor...Spotter
Ol Gray A
08-28-2006 17:48:37
 Re: TUNICA in reply to Spotter, 08-28-2006 16:28:47
Spotter, remember that we also said the carbs on these had to be of tractor origin. IE an updraft within 2 inches of original carb.
Spotter
08-28-2006 18:14:33
 Re: TUNICA in reply to Ol Gray A, 08-28-2006 17:48:37
Not exactly...the rules are posted on the website...Spotter
what about
08-28-2006 20:13:29
 Re: TUNICA in reply to Spotter, 08-28-2006 18:14:33
So, from the rules, it looks like the RD501 would be allowed in the modified classes but not the farmstock classes, right?
Of course, the rules state that you need stock motors in the Farmstock classes, so I should be able to drag the WD out of the garage and take it there. There won't be any stroker motors in those classes right?
Spotter
08-28-2006 20:39:17
 Re: TUNICA in reply to what about, 08-28-2006 20:13:29
Correct on all counts. There won't be any "strokers" in Farmstock if the rules are followed and your crystal ball is as good as mine in the regard...Spotter
what about
08-29-2006 04:06:19
 Re: TUNICA in reply to Spotter, 08-28-2006 20:39:17
So how are them rules enforced? Do you have to pay a protest fee? Only takes a few minutes to pull a spark plug and stick a piece of wire in there.
Eddie Haskell
08-29-2006 06:33:49
 Re: TUNICA in reply to what about, 08-29-2006 04:06:19
Go to greenpullers.com, the rules are there in black and white.
Info on protesting a tractor are explained in simple english.
whistler
08-29-2006 08:36:29
 Re: TUNICA in reply to Eddie Haskell, 08-29-2006 06:33:49
There is a handy littile device called a whistler, srews into the spark plug hole. Just turn the engine over and it keeps track of how many cubic inches of air comes out of the cylinder. Nascar uses them every weekend.
Drew
08-29-2006 10:09:08
 Re: TUNICA in reply to whistler, 08-29-2006 08:36:29
That would work, but you would have to have someone available at all times during the pull to operate this wistler, that actually knows what they are doing.
Also, a list would have to be drawn up BEFOREHAND that lists the accepable displacement for every tractor. This way, its in black and white and no one has to make a judgement call of whether an engine is too big or not.
Not saying its a bad idea to check, but just that it does take quite a bit of work.
Sounds Simple Enough
08-29-2006 11:14:49
 Re: TUNICA in reply to Drew, 08-29-2006 10:09:08
Never heard of this gadget.Cant see why it would not be used at the big pulls.
newbie1
08-29-2006 11:41:06
 Re: TUNICA in reply to Sounds Simple Enough, 08-29-2006 11:14:49
because they are about $1100, according to the guy at Summitracing that I talked to. They have one. For the accuracy we need, just use a piece of copper wire down the spark plug hole. If stroke is within 1/2" let it be.
