To the cam grinders out there
moli
08-25-2006 19:45:04
I know that some cam grinders read and post info.If possible can you PLEASE give me the stock camshaft specs (like you would have on a cam card) for a Moline U with the 283 in it..I cant find this info anywhere..THANK YOU.....Steve
the real CONFEDERATE
08-25-2006 19:54:48
 Re: To the cam grinders out there in reply to moli, 08-25-2006 19:45:04
.312" lobe lift intake & exhaust
188 degrees intake duration @.050" lift
198 degrees exhaust duration @.050" lift
108 degrees lobe separtion
If you need any other info you can call me Sonny Daniels @ Bullet Cams 662-893-5670
moli
08-26-2006 09:26:06
 Re: To the cam grinders out there in reply to the real CONFEDERATE, 08-25-2006 19:54:48
Thaks for the info on the cam specs..ill probably give you a call....steve
Travis M
08-26-2006 10:14:12
 Re: To the cam grinders out there in reply to moli, 08-26-2006 09:26:06
I have a cam done by bullet cams, excellent work, tractor runs great. I would recommend them to anyone.
