JD G tach
KD
04-04-2002 20:18:39
What is the best way to put a engine tach on a G.
G-MAN
04-05-2002 07:36:17
 Re: JD G tach in reply to KD, 04-04-2002 20:18:39
I think there was also a speed-hour meter option available - it would replace the governor end housing and drive off of that - although I've never seen one on a G, my 60 has one on it. It's listed in the G parts book, and you would have to replace the governor shaft, end housing, etc. and install a bracket, cable, and hour-meter. Like I said, I've never seen one on a G, so they might be pretty rare. Maybe there is another that would fit, like off of a 70 or something.
G-Man?
04-05-2002 11:02:46
 Re: Re: JD G tach in reply to G-MAN, 04-05-2002 07:36:17
I thought you went elsewhere?
That didn't look right
04-05-2002 11:09:45
 Re: Re: Re: JD G tach in reply to G-Man?, 04-05-2002 11:02:46
should have added welcome back I guess.
just trying to be helpful, you should do the same - thanks for the welcome back though
04-05-2002 11:17:59
 Re: Re: Re: Re: JD G tach in reply to That didn't look right, 04-05-2002 11:09:45
nt
JDGnut
04-05-2002 07:36:11
If you are running a gas dist, just set the tach to the 4 cylinder position, and it will work. If you are running an LP dist, you will have to find a tach that has a 2 cylinder setting. (good luck) If running a mag, find the inductive pick type, like burns was talking about.. JDGnut
Burns.. what's the part number on that Autometer tach.. and what's it looking like..(background, needle color) Looking for a different tach for the tractor I'm building... Thanks
burns
04-04-2002 21:08:29
The cheapest way is to purchase an electronic tach from a place like Northern Hydraulics. A wire picks up the impulse on the spark plug wires. It gets a little jumpy on the readings.
Other option is to install an MSD box. Most have a tach output. Depending on the tach, you can calibrate the tach for a 4 cylinder engine. I bought an Autometer 0-4000 rpm range that works great.
Gman
04-06-2002 17:28:53
 Re: Re: JD G tach in reply to burns, 04-04-2002 21:08:29
Fred does the Autometer tack plug right in to the MSD box or do you have to get one from MSD. I'ce got a plugin that goes to the magnetic pickup(Im using the white wire setup) it's purple and green,have't tried to plug it in to the Tack outlet yet do you know if it will plug in? '51 Gman
burns
04-08-2002 18:55:17
 Re: Re: Re: JD G tach in reply to Gman, 04-06-2002 17:28:53
The tach is equipped with 4 wires, 12v power, ground, wire for the internal light, and the tach wire. The 6A MSD box has a port for the tach. Pretty much wire to wire without needing anything from either autometer or MSD. It is my understanding that some setups require a adapter of some kind but I haven't came across that in my travels.
BTW, do you have any pictures of your G pulling that you would like to share?
Thanks
