Thanks Berry Cam Service!
Mopower
08-22-2006 05:34:05
I'd like to thank Berry Cam Service for their good work. After taking my M-M engine specs for compression, RPM, cubic inches, etc., their grind was great. The MM engine makes horsepower at a slightly higher range now and still idles smooth as silk. I was hoping to have a shot at strong a 3rd gear puller and now I can pull pretty strong in 4th. Not what I expected from a pretty basic G engine. Thanks! I was able to bring home a first place from the last pull. I will continue to recomend you to fellow pullers. Also many thanks to Doug Henderson at Henderson Power for installation tweaking the new engine on the dyno.
dboll
08-24-2006 05:02:02
 Re: Thanks Berry Cam Service! in reply to Mopower, 08-22-2006 05:34:05
I have been very happy with their grinds for case engines
PGpower
08-22-2006 09:39:17
It is always good to here about things working as good or better than expected!
