FullPullH, saturdays weather?
Kevin
08-18-2006 07:30:55
Just wondering what your thinking when you see tommorows weather? Not looking good for the pull tommorow at the fair. Im bringing the JD 60 to pull in 7500-9500 so im not loading tonight. If its not raining ill load up tommorow morning. Starting in 7500 i shouldnt have to be out there much before 12 or 1 anyways, right?
Location, Location, Locat
08-18-2006 10:55:00
 Re: FullPullH, saturdays weather? in reply to Kevin, 08-18-2006 07:30:55
And which part of the Planet might we be talkin here. Cause I haven't quite completed the mind reading course. Just kidding, it would be helpful if you would let us know where your going to try to go pulling at. Good luck with your pull.
Kevin
08-18-2006 12:39:31
 Re: FullPullH, saturdays weather? in reply to Location, Location, Locat, 08-18-2006 10:55:00
FullPullH will know were it is, but...if anyone is a weatherman im trying to determine the weather for the wyoming county fair in pike NY.
Full Pull H
08-19-2006 17:35:29
 Re: FullPullH, saturdays weather? in reply to Kevin, 08-18-2006 12:39:31
We got rained out during begining of 6500# div. 2. Not a hole lot of tractors but enough to give good competion. I don't like to brag but the H lived up to the name and won the 3500 and 4000 2 + every body else was only half way down the track !!!!! !!!!!
Kevin
08-19-2006 17:49:08
 Re: FullPullH, saturdays weather? in reply to Full Pull H, 08-19-2006 17:35:29
Sounds like you really have the H figured out. Sounds like i made a good choice becuase i was going to bring the JD 60 to pull in 7500-9500. Looks like i woulda unloaded and loaded right back up without pulling.
