tire spacing vs traction ?
Erik H72
08-17-2006 13:41:11
On my Oliver rc 66, I put the rear tires out about 3" each,(to re-install fenders) from being set in all the way. I was told my traction would suffer a little, Should I be concerned about this ??
770
08-17-2006 19:30:47
 Re: tire spacing vs traction ? in reply to Erik H72, 08-17-2006 13:41:11
Unless your going 20 mph, not to worry.
B-maniac
08-17-2006 19:05:41
Theoretically, on an open (unlocked) differential,the closer the tires are together, the more the tires will spin in unison without applying brake on one to get the other to spin. In my opinion you either need a locking differential or get real good at "feathering" the brakes so you get power to both tires at once if you want to win. I've seen guys start spinning one tire when they get slowed down and they don't even have their feet on the brakes and wonder why they can't place! Tire spacing,in my opinion,irrevelant.
Jeff Oliver
08-17-2006 17:40:04
No, I used to have mine on my 88 set out as far as they would go mainly because the hubs were stuck and it was easier to turn them around them move the hubs. The cool part of it is that if they go out far enough you don't throw dirt in front of the sled. Never hurt me that i could tell.
