Oliver 88 Stock cam specs.
J Schwiebert
08-17-2006 05:27:56
Does anyone have the opening and closing point of the intake & exhaust valve for a stock 88 cam? I am sure I have it but I don't want to dig through boxes to look for it. Thanks in advance. J.
Goldsburg
08-21-2006 03:34:14
 Re: Oliver 88 Stock cam specs. in reply to J Schwiebert, 08-17-2006 05:27:56
These were taken from a "used" 88 cam, so they may not be EXACT factory specs. It should give you an idea:
Intake
Lobe Lift: 0.237 in.
Duration: 169.8 crank deg.
Valve Opening: -14.3 BTDC
Valve Closure: 4.0 ABDC
Lobe Center Line: 98.7 crank deg.
Exhaust
Lobe Lift: 0.245 in.
Duration: 185.9 crank deg.
Valve Opening: 20.1 BBDC
Valve Closure: -14.3 ATDC
Lobe Center Line: 107.6 crank deg.
