A little Motor Knowledge IH H Help!!!
magman
08-15-2006 16:27:39
Hi Guys I have a question for ya? I took a stock 49 H motor and had the crank turned 20 thousands, Put Aftermarket high domes in it had the head stock H head plained about 60 thousands. New stock valves head all reworked. I polished the intakes in the head and 3oo manifold with a brake cyl hone. It has a 300 Cam shaft Used off eBay. And a Old M carb. and I also ground and reworked the Governor a little. So that's basically what I did to the motor. It has about 10 hours on the motor now and I am running 15 w 40 in it. OK I have run plenty of Hs a SH, a 300, And Ms, SMs,and lots of big IH tractors on the farm but this little H is something different. I have not checked it yet for RPMs But I have to believe its pushing over 2100 for sure and it screams. I am afraid to open it up. On the bush hog 5 footer in 3rd gear I cant find anything thick enough to have her over half throttle. I am also getting something Hot from the exhausted here and there landing on me. Is this old motor OK putting out Rpms like that or should I turn the bolt on the gov in some. I am running one of my own built mags on it also. Any Help would be appreciate JON
ChadS
08-17-2006 07:30:06
 Re: A little Motor Knowledge IH H Help!!! in reply to magman, 08-15-2006 16:27:39
Id back it down for sure on the rpms. The long bottom bolt inside the governor housing, adjust it closer to the housing to back it down. I would say 2000 is plenty, a Super H at 10%over is 2050, you will be ok there if its solid. Do ya have an old muffler on it? That may be whats shooting hot material out the manifold, A piece of old rust, or carbon in the exhaust can come loose ??? Chad
magman
08-17-2006 09:35:49
 Re: A little Motor Knowledge IH H Help!!! in reply to ChadS, 08-17-2006 07:30:06
No brand new muffler but I guess it could be coming from that used manifold I bought I did not have it soaked or anything. Thanks for repling I knew you could tell me. LOL JON
ChadS
08-17-2006 11:38:03
 Re: A little Motor Knowledge IH H Help!!! in reply to magman, 08-17-2006 09:35:49
Yeah, kinda what it sounds like. maybe put a spark arrester on it for a while? Metal screen, longer pipe extension on the muffler? Chad
Ken B
08-16-2006 16:20:15
Go on and hook to a sled and see how proud you are then. It's a differnt type of power needed .
magman
08-17-2006 07:25:04
 Re: A little Motor Knowledge IH H Help!!! in reply to Ken B, 08-16-2006 16:20:15
Oh I have hooked to many sleds, If it was not for a bad back this little girl would be stripped down and have the tires off my loader h on her and heading to the next pull. Thats what she was origanelly built for.. But the injury has side lined me. She needs a little more breaking in on a disc or something and some fine tuning . Tghen if I can find a big boy to rangle tires and weights she will hook. JON
JakeF
08-16-2006 07:25:48
You need to find out how many RPM it's at for sure, not just the ol seat of the pants/ear tach. I'd keep it at 2000 or less if it's just getting used around the farm.
magman
08-16-2006 09:45:24
 Re: A little Motor Knowledge IH H Help!!! in reply to JakeF, 08-16-2006 07:25:48
I tryed hooking up a tach on her but could not get a true reading becuase of the Magneto. JON
JakeF
08-17-2006 00:23:15
 Re: A little Motor Knowledge IH H Help!!! in reply to magman, 08-16-2006 09:45:24
If I put on an automotive style wire that isn't solid wire I can get my snapon to read correctly. You may try it with yours and see if that works.
magman
08-15-2006 16:36:37
I just wanted to add that I have 150#s compression dry and 160#s wet compression on all cylinders. I actually think this tractor would be putting out close to 2500 RPMs if thats possible. JON
