9-Bolt hub adapters
JD A
08-12-2006 14:47:10
I need a set of 9-Bolt hub adapters for my A.
Mike Aylward
08-12-2006 15:49:03
 Re: 9-Bolt hub adapters in reply to JD A, 08-12-2006 14:47:10
JD A, you really don't need "adaptors". All you need is a set of factory 9-bolt hubs for your A tractor. They are readily available. Hope this helps. Mike
JD A
08-12-2006 16:09:13
 Re: 9-Bolt hub adapters in reply to Mike Aylward, 08-12-2006 15:49:03
Where can I find some?
mjjk
08-12-2006 20:37:33
 Re: 9-Bolt hub adapters in reply to JD A, 08-12-2006 16:09:13
I have a set of adaptors out in the shed I made a while ago if yuo are interested
JD A
08-13-2006 06:27:16
 Re: 9-Bolt hub adapters in reply to mjjk, 08-12-2006 20:37:33
I am interested. Where are you located.
mjjk
08-13-2006 10:41:58
 Re: 9-Bolt hub adapters in reply to JD A, 08-13-2006 06:27:16
I am in the eastern part of iowa,very close to Dubuque Iowa.
