What do you fellows think?
Jerry Cent. Mi.
08-08-2006 18:41:08
I pull with 16/9 X 34 tires on a 12 inch wide rim and wonder what the advice would be about high or low tire inflation on a hard track.
Steve Van Drimmelen
08-09-2006 13:38:53
 Re: What do you fellows think? in reply to Jerry Cent. Mi., 08-08-2006 18:41:08
I run 16.9x34s on my stock tractor with about 10-11 lbs of pressure. My rim width is 15" and the holes I dig seem to be fairly even. This is in 5,500 and 6,500 lb classes. Hope that helps.
Mike Aylward
08-08-2006 19:44:36
Jerry, first of all, it won't make much difference if you are running only a 12 inch rim. That isn't nearly enough rim for a 16.9 tire. You need to be using AT LEAST a 14" rim and a 15" is the recommended size for that section tire. A 16" rim actually works the best. You can try all kinds of air pressure but your rims will not allow you to use the potential of the tires you have. A 16.9-34 tire works very well on the correct rim. Mike
b barenie
08-08-2006 19:35:26
16.9-34's fat sloppy and lazzy !
what does your foot print look like at the end of the pull ? concave or convex !
draw bar height dropp's with heavy weight and low tire pressure. Low pressure loose a ton of hitch heigth , at the end of the pull !
Good tight track more pressure, if you got enough juice under the hood ! Lower pressure, if you need slippage to keep the motor in the hunt !
Haven't pulled in a couple of year's, but that rim width is to narrow ! Mfg suggested 15's I think ? an inch under would be ideal !
7000lb class 15.5-38's (co-op's) on 14" rims hooked well at 14.5-15.5 lbs in all condition's
Just my opinion ! Got to keep the center of the tire in contact with the ground !
chadah
08-08-2006 19:06:51
If you have the power I think lowering the pressure helps.
