whats the best tractor
zach77
08-07-2006 15:44:56
I am almost done restoring my 51 jd B and when I am done want to build a puller. I am only 15 so I dont have the most money in the world. What would make a good beginer project. I do not care what make or model.
so in other words what would make a good pulling tractor Thanks Zach
85_Ranger4x4
08-07-2006 19:08:49
 Re: whats the best tractor in reply to zach77, 08-07-2006 15:44:56
A WD-45 is a good choice too. It is hard to find another stock tractor that puts out over 40 hp and can run in 4000. I pull a 53 and it places fairly often unless I do something stupid, only mod is 3" chrome exhaust pipe. A diesel oliver would be my next choice.
mm705
08-07-2006 19:03:31
Well I am 19 and am building a MM 705. Not a good beginner! I got to deep into it and now if I dont go ahead and build it, it wont be worth anything. Anyhow I pulled 77 and 88 olivers and had a alot of fun the 77 was my beginner.
80kid
08-07-2006 18:45:06
well i am 16 and i have a couple of pulling tractors i had a 49' B that was pushing 38 Horse power... now my dad and i have a 53'R and an 56' JD 80 that is pushing lots of power... i cant keep any of them on the ground..
keep it up and e-mail me if u want were are u from
alex
u m-m
08-07-2006 18:34:55
A U Minneapolis Moline you can get for a fair price and run all stock in the 5500, 6000 and 6500 lb classes and has plenty of power and speed to get through the slow tractors spim out ruts on the track. For a little more fun and not much more money you can install power unit 403 motor and pull up to the 10,000 lb classes and still come out on top. JUST AN OPTION FOR SOME GOOD CHEEP FUN
johndeereman
08-07-2006 17:03:02
well im a little older than 15 but probably even less money to work with i have a wife and three kids to support a dc case is a great puller i just bought one the motor is stock and whipped baddly in the 7000 class i can be in the top ten of thirty to forty tractors always spin out though but im trying new things hopefully i can solve that prob
fmpuller450
08-07-2006 16:13:41
well i am also a 15 year old and i have a farmall super h and its a all around good puller
mostly stock with a slow 1st gear for power the only problem i have is i cant keep it glued to the ground
FarmallHPuller
08-11-2006 10:56:06
 Re: whats the best tractor in reply to fmpuller450, 08-07-2006 16:13:41
Put some big tires on your super H and that should put a pretty big load on it. I know it does for mine.
