Pushing fuel?
MJD255
08-07-2006 03:06:31
Looking at pushing fuel to a 1456 With 4x.24inj,.093lines,and 3lm. Tractor runs good but want to try pushing fuel at the next pull. a lot of guys around here are using Shurflo pumps on there 1066's. will this work for me? If so how much pressure do I need to run, I have a Shuflo sittng on the shelf rated at 2.8 Gpm at 40Psi. If I do this will I need to run the pump all the time or will my Roosa pull the fuel through the electric pump while the tractor is idleing? I remember talking to a guy who was pushing with an electric rotary but he had to turn it on and off while he was waiting to pull because it would run out of fuel without it on and if he left it on the pump would get hot and quit as it had no relief on it. Any Thoughts ? Thanks MJD
G/MAN
08-07-2006 13:32:09
 Re: Pushing fuel? in reply to MJD255, 08-07-2006 03:06:31
Turning it on and off seems sort of ridiculous when you could simply install a variable pressure switch to control it, or install a pressure relief valve to return excess fuel to the tank.
Dero
08-07-2006 18:25:24
 Re: Pushing fuel? in reply to G/MAN, 08-07-2006 13:32:09
Why not add a bypass regulator. This way the lift pump would not dead head at idle.
MJD255
08-07-2006 20:16:52
 Re: Pushing fuel? in reply to Dero, 08-07-2006 18:25:24
I was planning on bypass but how much pressure do i need to keep the Roosa full> I slapped on the shurflo to see how it would work and left it to cycle on and off but was thinking i would be better to disconnect the cycling and run it through a bypass with constant press.> It seemed to want constantly cycle otherwise. I"m afraid the pump will give up on me if I don"t. I still wonder will the shurflo work and will I benefit from it or am I wasting my time??
