powerblock puller
Cliff D
08-06-2006 18:36:57
hello, i have a 51' jd "a" with a 6-3 power block. im 17 and have got the fever! i need more power and have herd about people boaring out powerblocks with 6" boars and punching them out .125 and putting stock 6.125 "g" pistons into these powerblocks. what other modifications would i need to do becides milling off the top of the piston because the wrist pin sits 1/8 of an inch farther forward then an "a"s pin. LOOKING FOR SOME ADVICE FROM THE EXPIERIENCED PULLER BUILD A CHAMP!!
Cliff D
08-07-2006 15:52:05
 Re: powerblock puller in reply to Cliff D, 08-06-2006 18:36:57
SO WHAT WVERYONE IS SAYING I SHOULD INDEED STROKE MY ENGUINE(AROUND 8 1/2" - 9"), BUT KEEP THE 6" BOAR WITH HIGH COMPRESSION PISTONS. THE HEADWORK MAY NOT NECESSARLY DONE WITH MY STOCK "A" HEAD BUT A 60'S HEAD IS COMPATTEBLE AND THAT WOULD WORK AND GIVE ME MORE POWER. ANYTHING ELSE???
KEEP WRITING!! KNOWLAGE IS POWER..... WELL POWERBLOCK...
-CLIFF
jdlover
08-07-2006 09:14:09
75 h.p. without stroking an A?youre nuts get into the crankcase young man and you wont be happier.
Kevin
08-07-2006 11:36:11
 Re: powerblock puller in reply to jdlover, 08-07-2006 09:14:09
Let me clear that up, it not in an A, its with a 60 with a 6-3 power block. I am going to go for it this winter, i have been garenteed to get real close to 75 hp with no extra stroke if not right at 75 hp. I know the extra .125 of piston osnt going to be were the power comes in, its going to be the way these pistons are designed and all the head work that is going to bring in the big power. Right now my 60 is old and worn out with a 6-3 power block that is totaly stock and original never been rebuilt and it has alot of blowby and i am still seeing 55-60hp out of it. Maybe i should be keeping this set up a secret. If you want a real good set of pistons try calling Bob at Tripple G 1-888-720-0830
sorry....
08-07-2006 11:52:22
 Re: powerblock puller in reply to Kevin, 08-07-2006 11:36:11
sorry..but you are goin to bite the bullet if you think jsut that is going to give you 75 hp. we got an A with a 6-1 powerblock and 60 head and 8" stroke and it is only seeing 72 hp..... sorry to burst ur bubble...
Kevin
08-08-2006 06:52:42
 Re: powerblock puller in reply to sorry...., 08-07-2006 11:52:22
Im not going to sit here and argue about the situation. You could posibly be right. I will let you all know when i get it on the dyno after we build it, thats the only sure way to find out.
deere puller man
08-07-2006 14:40:19
high compression and big time head work may give you the horsepower but you'll sacrifice torque and the tractor won't lug near as well. Look at it like this: Say you've got two engines from the same model tractor. Both have 75 horsepower, but one has been stroked to get the 75 and the other has done it through high compression and headwork. The stroked motor will consistently outpower the non-stroked motor on the track because it will have a lot more torque.
Cliff D
08-07-2006 08:52:18
KEVIN and DSK,where do i order these pistons and cranks, also what type of headwork would i need to do. bigger valves and guieds....?? milling..
i appreciate the feedback! -CLIFF
DSK
08-07-2006 12:12:08
 Re: powerblock puller in reply to Cliff D, 08-07-2006 08:52:18
There are many good crank builders throughout the country. Opinions of them will vary depending on each individuals experience with them. It is my opinion that you should choose a builder that can put together a complete package with compatible components and stick with them. You can check with Keith Merfeld in Peosta Iowa, (563)582-8710, or Al Schooler in Princeton, Mo. (660)748-4475. At any rate, don't expect to see your crank for 90-120 days, so send it out early or get yourself another crank so you can still play with your tractor until the job is done.
DSK
08-06-2006 23:13:59
The time and money it will take to go to 6.125 will not be worth the small HP gain you'll get. If you're looking for the most bang for your buck, stroking is the way to go. If you stay under 9" you should be able to use the stock Powerblock pistons. By going to an 8.5" crank in that A, you'll gain about 99 cubes, which should get you about 75 HP. By going to 6.125 bore,you will only gain 16 c.i., you might see a 5HP gain or less with the stock PB c.r. of 6.5-1.
John179
08-07-2006 09:19:39
 Re: powerblock puller in reply to DSK, 08-06-2006 23:13:59
How can you bore out 70 power block. or whats the largest piston you have herd of going into a 70 power block
DSK
08-07-2006 11:44:47
 Re: powerblock puller in reply to John179, 08-07-2006 09:19:39
If you want to save a lot of headaches and money by not resleeving, the 6.675 bore pistons from Murphy's Motor Service are a good way to go. (see website) They will build a set to your specs. This is about as far as you can go in the stock PB sleeve and maintain some durability.
Kevin
08-07-2006 06:06:14
DSK, i know of a custom piston setup that is 6-1/8" and extensive head work that is seeing 75hp with no stroking. This is not using stock G pistons, these are custom high compresion aluminum pistons.
JDGnut
08-06-2006 19:48:06
If you machine the G pistons.. you have to turn the diameter of the tops down.. not just cut the top off.. So the top of the piston enters the smaller counter bore.. Giving you more compression... Or you could go to a set of custom pistons... JDGnut
