Stroking a JD 70
John179
08-05-2006 09:35:52
I was wondering how far I can stroke a crank on my 70 before I have to do some major machining. And where would I go to find a rpm tach for my tractor. I would feel alot better knowing the amount of rpm's I am running. Thanks for any info.
DSK
08-05-2006 18:40:40
 Re: Stroking a JD 70 in reply to John179, 08-05-2006 09:35:52
My 70 is 9" which is a small 70 by todays standards. Merfeld did the crank & rods for me as well as the clearance grinding on the rods. I spent about 1/2 hour inside the case with my hand grinder and everything cleared, the 70's have a lot of room inside the case. I had the cam cut down to .625 between the lobes also but I wouldn't have to have gone near that far. None of this is considered any where close to radical clearancing. It depends mostly on how your rods are set up mostly, the back of mine are from a 4020 gas and the front are from a styled A, but no matter how you go you won't have much trouble making anything under 9.5 fit easily.
John179
08-06-2006 18:26:52
 Re: Stroking a JD 70 in reply to DSK, 08-05-2006 18:40:40
I would like to talk to you more about it maybe I could give you a call .
