Oliver 88 power
Farmall H Pulle
07-31-2006 19:55:04
What are some of the best way's to get power out of an 88 that already has 3 7/8 m&w piston's in it. I don't want to spend over 700 dollars.
Oliver88puller
08-04-2006 09:46:24
 Re: Oliver 88 power in reply to Farmall H Puller, 07-31-2006 19:55:04
take your 3 7/8 m&w sleeves and have them bored to 4 inch then get some 4010 gas piston from the local John Deere Dealer for cheap out of an over haul. Then if you can have them machined down to fit in the head run about 14.5:1 compression
JD hauler
08-01-2006 14:38:17
Are you running a ported head and matched intake runners? if not your missing the boat on more cheap power, and the 1650 intake/exhaust will bolt right on, try some other carbs , bigger isnt always better unless its cut back some, but gotta get the air in that motor, use electronic ignition, it wont gain you any power , but holds the tuning you do alot better, this should help some for cheap.
770
08-01-2006 14:49:02
 Re: Oliver 88 power in reply to JD hauler, 08-01-2006 14:38:17
Amen to that. On my 77, I ported the head and matched it to the intake runners and it got me 7 horse even on the dyno.
Jeff Oliver
07-31-2006 20:37:44
Ask for a fella on here called Real Conferderate.He owns Bullet Cams, He can probably fix you up with something.
Ken B.
08-01-2006 04:12:04
 Re: Oliver 88 power in reply to Jeff Oliver, 07-31-2006 20:37:44
Jeff what are you doing this weekend? I have some I have some free time and could come down and look at that 88. Ken
Jak
08-01-2006 10:14:04
 Re: Oliver 88 power in reply to Ken B. , 08-01-2006 04:12:04
Oh no,we don't need another 88 pulling here.LOL!Wouldn't you rather have something else Ken?Jack(TN).
Ken B.
08-01-2006 17:15:25
 Re: Oliver 88 power in reply to Jak, 08-01-2006 10:14:04
You know someone has to take up the slack between your hip and my back .We need another OLIVER in the Pulling line and Sam need to get Off that ol red thing haha.Send me Jeff's email I'm at Ft Knox and don't have it on my address book Ken B.
