IH D282 injectors
Red Mule
07-30-2006 07:47:37
Has anyone here heard of or seen a replacement type injector that uses a pencil type injector instead of the factory deal for these engines. something along the lines of makin a new injector body then installing a 400 series injector in it. Heard of this being done but have never actually seen it.
IHC PULLER
07-31-2006 15:38:07
 Re: IH D282 injectors in reply to Red Mule, 07-30-2006 07:47:37
I HAVE SEEN WHAT YOU ARE TALKING ABOUT. THEY TAKE THE GUTS OUT OF THE 282 INJECTORS AND MACHINE THE INSIDE TO ACCEPT A 400 SERIES INJECTOR LETTING THE TIP STICK OUT OF THE BODY AND SPRAY FUEL INSIDE THE PRE CUP. THIS IS A GOOD THING IF YOU ARE PUTTING A TURBO ON SO YOU CAN RAISE THE INJECTOR OPENING PRESSURES UP.
Red Mule
08-02-2006 05:50:04
 Re: IH D282 injectors in reply to IHC PULLER, 07-31-2006 15:38:07
But who is it that is making those style injectors?
brianIH
07-30-2006 19:21:33
contact your local diesel man and he can order the parts for you.They are expensive like $100 to $200 apiece.But I don't think they will give you$600 more power.
