One more unstyled B question
Kevin
07-27-2006 16:41:52
Well a day or two ago i posted an unstyled B question about tires. Now i was wandering about weight. According to tractor data they were around 2700 shipped. I was told they can make 2500 easily. Did i hear someone wrong or is this correct? Id imagine 2500 is were one should shine with the farmall A's.
mr.thinker
07-27-2006 20:51:54
 Re: One more unstyled B question in reply to Kevin, 07-27-2006 16:41:52
it would take sone work to get that light, consider welding plattes for hubs onto your axles, and cut off the excess, will save ya 50-70 lbs or so depending on the offset of your pressed wheels?
jd b puller
07-27-2006 19:03:30
Seems like a lot of the clubs are getting rid of the ultra light classes, or there's just 1 or 2 tractors in them if they have them. I think it'd be tough to pull an US B in the 3500 and 4000 unless you really know what yer doin. There's US B's out there that shine, but you gotta consider who's running and building them.
john dear
07-27-2006 17:26:28
I have a 38 unstyled B with round spokes on both ends. Weighed pretty close to 2,800 with me on it (+225). I suppose with light hubs and stamped wheels you might get to 2500 with a kid on it. Not much weight to loose without cutting the axles off, putting a stamped back on it, and stopping eating for a year or so. We don't have a 2750 class in this part of the world so 3500 was the lightest we could pull. Underpowered and under tired for that class. Maybe there is someone with a 2500 pounder that can tell you how to get there. Might be hard to do and still pass it off in the 'stock' class.
Kevin
07-28-2006 15:25:11
 Re: One more unstyled B question in reply to john dear, 07-27-2006 17:26:28
Sounds like i will have to settle for 3000lbs as i dont have the heart to chop up such a nice deere. I wont go as far as sawing off axels. If i can do or undo with a wrench im willing but im not touching her with a saw.
49 A Puller
07-28-2006 23:35:07
 Re: One more unstyled B question in reply to Kevin, 07-28-2006 15:25:11
I haven"t checked the parts book to see if it can be done, but I know that with the model As, you can swap out the axles and bull gears to later ones that are a dime a dozen, and I would imagine you could do the same with the Bs. Then you could butcher the axles all you want, and should you ever want to put the tractor back to original, it is only some wrenching away. Also, should you not want to go to weld-on hubs, finding 9 bolt hubs for late styled tractors is far easier than finding them for unstyleds.
Some other things that I"ve done with my A to lighten it up could apply to you too, although the losses won"t be as much, you can nickel and dime quite a bit off without changing the outward appearance. I am running a piece of PVC for the lower water pipe (-5 lbs.), you can do away with the PTO shaft and coupler, and just make plate to bolt onto the stock flatback cover, and bolt a stub of a pto shaft onto that (-15 lbs.), you could make a new seat channel out of aluminum, and do away with the spring and just use a short bolt, doing those two should drop an easy 10-15 lbs, and once you slap some paint on it, no one will be the wiser. Also, if you"re able to find another steering shaft/spindle assembly, cut the spindles off and weld on some off of an M, and use the M hubs. They have the standard 6-bolt implement wheel bolt pattern, but weigh about half of the standard 6-bolt front hub for the A and B (-25 lbs.) One last thing to check is which frame you have. Although the parts book doesn"t list there to be many different frames, there are some which are full of cast, and almost box in the lower water pipe, while others are basically just two heavy angle irons, and depending on which one you have, there could be some pounds to be dropped there too.
There is alot of things you can do to drop some weight without being noticed by someone walking by your tractor, and all of it can be changed back to original with some wrenching, although some things require far more turns of a wrench than others.
Hopefully this will give you some ideas and get you on your way.
