tires
rpllr
07-27-2006 05:02:36
Does anyone know what the differece in mph there is between a 14.9 38 and a 13.6 or a 12.4 38. Is there a formula to figure the speed by the circumfrance of the tire? Thank you
720Deere
07-27-2006 05:07:25
 Re: tires in reply to rpllr, 07-27-2006 05:02:36
If the 14.9 has 10% more circumference than the 13.6 then your mph should also increase 10%. I didn't bother to look up the tire dimensions. I just used 10% as an arbitrary figure.
You are not going to gain very much mph unless you go from say a 34" wheel size to a 38". I can't imagine you gaining much more than .2 mph unless you drastically step up your tire size.
