mixing diesel
D-Day
07-25-2006 12:49:07
I have heard that you can mix some kerosene into diesel fuel and use it in a diesel engine for some extra power (more fire= more power.) Is there any truth to this?
Thanks in advance for any help.
RFH
07-26-2006 04:32:18
 Re: mixing diesel in reply to D-Day, 07-25-2006 12:49:07
We'd often put some kerosene in with the diesel during the winter to keep the fuel from gelling in the dump trucks. I never noticed a difference in their performance.
massey333
07-25-2006 16:44:06
Not scientific by any means,but back in the 60s when we testing fuels for pulling HP,(our own Dino.)A light #2 would help a Direct Inj.engine(JD&AC)and hurt a INDIRECT engine (Case-Older JD-Oliver)where a HEAVY #2 was just the opposite results,hurt the direct helped the Fuel Cell engines.Kero.has less Power Properties.Example I had to buy a 50-50 blend Diesel in Fargo ND and lost a gear(overdrive vs Direct)going west onI94.Went back to regular #2 and picked the gear back up.
Leland
07-25-2006 16:06:41
I was always told the thinner the fuel the less power you get , so I would find a way to thicken it up , maybe add a propane bottle and that will give it a boost .
