speed vs hp
stock puller
07-24-2006 17:31:26
when stock pulling does speed factor in pulling distance like in truck pulling or is more hp when pulling the last 20' better for stock pulling thanks
dboll
07-25-2006 13:46:55
 Re: speed vs hp in reply to stock puller, 07-24-2006 17:31:26
It always makes me laugh to hear people who can't win pulling just assume the winners had to cheat. If all factors are the same, ie; weight, hitch, tires,speed, rpm's ect. Explain how they are cheating? I have beaten alot of high dollar stuff by knowing how to weight my tractor, driving ability and luck also figure in to the equation. An underpowered tractor will hit peak torque sooner, transmitting that torque to the rear tires causing them to break traction. A tractor that can idle down to stay under a speed limit then add throttle as the load comes on to maintain a certain speed will most generally have an advantage.
MJF
07-24-2006 18:38:33
First gear and the most traction. I can outpull tractors with nearly twice the hp in a pace pull.
mr.thinker
07-24-2006 18:56:45
 Re: speed vs hp in reply to MJF, 07-24-2006 18:38:33
mjf you must pull a deere, if not i guess everyone gets lucky from time to time?
MJF
07-25-2006 19:36:26
 Re: speed vs hp in reply to mr.thinker, 07-24-2006 18:56:45
Thats an insult, pullin a deere.
mr.thinker
07-24-2006 18:19:36
around the natpa circus and my neck of the woods,your limited to speed and yourfirst gear. speed always helps and horse power helps even more. the best advice no matter what class is to cheat, cheat, and most of all don"t let them know your cheatin!
hooked
07-25-2006 13:10:56
 Re: speed vs hp in reply to mr.thinker, 07-24-2006 18:19:36
Like my cousin, who runs a sled in southern and central NY says - at the end of the day two groups leave the pull - the losers and the cheaters
should be
07-24-2006 19:02:02
That's nice!
