MORE RPMS
DEARLY
07-24-2006 17:16:56
NEED TO GET MORE RPMS OUT OF MY FARMALL M
MJF
07-24-2006 18:41:36
 Re: MORE RPMS in reply to DEARLY, 07-24-2006 17:16:56
You could always wire the governor spring, better hope you have a tight engine though. I wouldn't suggest it.
mr.thinker
07-24-2006 19:01:48
 Re: MORE RPMS in reply to MJF, 07-24-2006 18:41:36
your right mjf' but my thought's are why more rpms, is the hay down and rain coming in?
Hayfarmer
07-24-2006 18:21:12
INside the governor is a screw where you set the RPMs. If you back that out you can get higher RPMs. You may also have to adjust throttle linkage and also helps to put a heavier or at least new spring in the governor while you are there. You don't want to kick it up toomuch especially if you have the old style cast pistons.
DEARLY
07-25-2006 14:22:49
 Re: MORE RPMS in reply to Hayfarmer, 07-24-2006 18:21:12
THIS IS A BRAND NEW 450 MOTOR WITH HIGH DOME PISTONS ALUMINUM
MJF
07-25-2006 19:39:39
 Re: MORE RPMS in reply to DEARLY, 07-25-2006 14:22:49
why do you need more rpm's with that setup. But really just adjust the bolt in the governor and throttle linkage, that all you need to do
