IH Pump question
Mark Redman
07-24-2006 13:25:26
I recently purchased a 13mm model 100 pump that I put on my 706 with a 466 motor in the tractor. I hooked two times to the sled and she ran beautifully. The third time down the track, the tractor just died. I found that the cross at the back of the pump that drives the piston broke. I fixed it and hooked to the sled again. I broke it again!! Any help as to why this piece is breaking would be greatly appreciated.
Donnie T
07-24-2006 15:28:05
 Re: IH Pump question in reply to Mark Redman, 07-24-2006 13:25:26
Did you change injector lines? You have to change them to a biggger size for the 13mm head in the pump. You can get by with the same lines on a 11mm head but not the 13. The pump will pump more fuel than the lines can handle. Thus causing alot of back pressure in the pump.
