Spark Plug gap
jhb
07-22-2006 04:37:04
Been running .025 plug gap on a Super M 281 stock with 150# compression and changed to .030.
Should this be an advantage or no change with standard rpm and electronic ignition?
Ian Johnsen
07-25-2006 21:47:29
 Re: Spark Plug gap in reply to jhb, 07-22-2006 04:37:04
Typically a tighter gap will increase RPM capability with a loss in torque, and A looser gap will increase torque and lose RPM
jpl
07-22-2006 07:40:03
you wont see or feel any changes since you have 150# comp and low rpm. been there. with super high comp and high rpm you may want a closer gap, but that is only my seat of pants from running gassers back in the early sixties. get the petronix high voltage coil also with your electronic ignition.
