horse center pull VA
ported
07-19-2006 08:38:12
Did anyone make it to this pull last night? I heard there were some ground pounding JDs there that took all the 6mph classes, could'nt make it had to work.
real green
07-22-2006 16:43:04
 Re: horse center pull VA in reply to ported, 07-19-2006 08:38:12
Somebody must be blowing smoke up someone's butt!! The little fawns ran home with their tails tucked. I guess it carried over to saturdays pull. Must have to regroup a little. Good thing you could only pull one time or the big bad 88 in the 6000 would have to play in the 7000 and spank some more bambi's.
Mr. Tinker
07-21-2006 09:51:35
My JD "A" won the #7000, 3 1/2 mph class. The next six or seven tractors were all JD "G" tractors. The rest of the field were IH "M"s and such.
scratching
07-21-2006 01:48:44
there was a lady pulling a 77 oliver that had to pull off with JD A in 4000, almost got him.
double trouble
07-21-2006 18:20:43
 Re: horse center pull VA in reply to scratching, 07-21-2006 01:48:44
I saw a few women get wins one in the 2500lbs 3.5mph class on a farmall a, one in the 4500lbs 3.5mph class that won the pulloff on a jd a,one in the 6000lbs oldies on a jd unstyled g.
pullin
07-20-2006 17:22:20
would not let any competition pull ,club seems to only want their local members to pull,also have 1954 cut off,
black m
07-22-2006 16:32:47
 Re: horse center pull VA in reply to pullin, 07-20-2006 17:22:20
this is a fair pull. one club puts it on another club supplies the sled. if you was much competition you would have showed up!!!
wcac
07-21-2006 02:03:50
they wouldnt let me pull a wc with 38" rears but you could pull cut tires, go figure
olie 66
07-22-2006 16:35:59
 Re: horse center pull VA in reply to wcac, 07-21-2006 02:03:50
if you would have ran 28's you would have still got your doors blown off
double trouble
07-20-2006 19:41:40
Well I know that in the 4500 6 MPH class a hot 88 oliver put a stroked JD junker on the trailer!!!!!
Mr. Thinker Jr.
07-21-2006 04:19:00
 Re: horse center pull VA in reply to double trouble, 07-20-2006 19:41:40
Just wondering where do you get a stroked shaft for a H J.D.
