higher ring and pinion
need speed
07-18-2006 19:10:16
Is there a higher ratio ring and pinion for a Farmall 560?
need speed
07-19-2006 17:17:33
 Re: higher ring and pinion in reply to need speed, 07-18-2006 19:10:16
thanks for the info
Greg Lussetto
07-18-2006 21:50:14
Farmall 560 and 660 R&P 3.27:1
International 560 R&P 3.07:1
Farmall MTA, 400, 450 2.63:1
International 6TA, 400, 450 2.48:1
Sheepdog in NE
07-18-2006 19:46:47
A 450 had a lower RPM engine so the ring and pinion sped up the tires. Don't know what percent tho, did at one time. Someone out there is smarter than me or you could figure it out by counting teeth. It will fit if you use the 450 bolt and washer and not the snap ring. You'll see when you get it. Got one on the shelf. Tried it and it was to fast for our situation. Went back to the 560 one. Good luck.
