Why do they start the pulls with small tractors fi
Roger in Iowa
07-17-2006 05:31:00
Went to tractor pull at the local 4-H fair Friday evening. Supposed to start at 6:30 and had sled electronics trouble and did not get going until 7:30. Watched until 11:30 and they were still running the same 12 to 15 tractors and were only up to 7000 pounds or so.
Questions I have:
1. I have seldom seen the big tractors pull as it gets so late (1 or 2 in the morning)! Why don't they start with the big ones sometime or flip a coin and see which starts first? Need some variety, please.
2. Could they add more weight (believe it was 500 pounds per different class) to cut down the class numbers? Got tired of the same tractors.
It was interesting to see what more weight would do, and some did better, but enough already.
Enough on the rant.
Roger in Iowa
nc jd guy
07-20-2006 06:37:19
 Re: Why do they start the pulls with small tractor in reply to Roger in Iowa, 07-17-2006 05:31:00
Just be lucky they go "high to low" or "low to high" - I got this off one of the North Carolina Clubs page. Great variety if you are a spectator, but in reality, how many spectators are there besides the family? Doesn"t matter what you pull, you are there all day long.
#1 ORDER CLASSES WILL PULL:
1. 7200 LB. STOCK
2. 5200 LB. STOCK
3. 3700 LB.SUPER
4. 2700 LB. STOCK
5. 4500 LB.5MPH
6. 4200 LB. MODIFIED
7. 6500 LB.5MPH
8. 4700 LB. STOCK
9. 7200 LB. SUPER
10. 9200 LB. STOCK
11. 4700 LB. SUPER
12. 6700 LB. STOCK
13. 4700 LB. MODIFIED
14. 5700 LB. STOCK
15. 5500 LB 5MPH
16. 8200 LB. SUPER
17. 8200 LB. STOCK
18. 5200 LB. MODIFIED
19. 3200 LB. STOCK
20. 6200 LB. STOCK
21. 9200 LB. SUPER
22. 4200 LB. STOCK
23. 4200 LB. SUPER
24. 10,200 LB. STOCK
25. 3500 LB. 5MPH
26. 5200 LB.SUPER
27 3700 LB. STOCK
28 6200 LB. SUPER
Dairy Farmer
07-18-2006 17:27:32
Have you ever seen ALL the tractors that pull in one pull there before the pull starts? A lot of the big pullers would miss out because they were too late. The lighter tractors dig shalower holes. But at the Polk County WI pull they do the modifieds sooner because they do the pull at night and there are campers on the Fair Grounds. Just my 2 cents.
OU812
07-18-2006 19:08:14
 Re: Why do they start the pulls with small tractor in reply to Dairy Farmer, 07-18-2006 17:27:32
If you would all look at a previous post where's the the blade and the roller? An 18.4x38 tire will dig a hole regardless of the weight, if it spins out, unless you have a noncut tire class.If you don't agree with me just take a look at Outlaws, NTPA, or go to Louisville they all mix them up.
OU812
07-18-2006 18:56:20
The reason the BIG pullers show up later is because we know we will be the last ones to hook.
85_Ranger4x4
07-18-2006 10:16:18
We reverse the order every other pull, most people hate it. The guys that actually pull have to take their weights off the tractor as they pull, and then put them back on to go home. The lighter pullers have to dodge the massive holes the heavier tractors make.
Ian Johnsen
07-17-2006 19:30:02
Our club runs two sleds. Our big sled is self powered, and our small sled requires a pull back tractor. We start with 3000# on the small one in 500# increments. The big sled starts with 6000# and goes in 1000# increments. The sleds run side by side in an alternating fashion. We get bored with seeing the same tractors pull over and over so each tractor is only allowed to pull in 2 classes. Invest in less weight and buy more tractors. It makes for a good length show with v-8 modifieds, hot farm, and trucks afterwards.
730-LP
07-17-2006 18:58:45
Where I pull we start at 3000 then 4000,5000,6000,7000 then back to 3500,4500,5500,6500,7500.The next pull we pull in reverese order
720Deere
07-17-2006 17:57:32
If you want to thin out the lighter classes, just let the heavy tractors pull first and see how many pullers you lose! I pull from 9000 to 12000 and always seem to wait around 5 to 8 hours to pull while the 3000 lb tractors have been home for lunch, mowed the lawn and have had several beers before I pull. Maybe 2 pulls a year we get to go first and the little guys whine about how bad the track is by the time they pull. No kidding! Don't you think it's a mine field when we pull after 150 or more tractors have made their runs?
It sure is easier to start heavy and throw off weights as you go rather than add weights as you go. The whole thing is just like being married: the smaller species will always get their way while the larger species patiently suffer! I guess when you can barely count forwards, it's next to impossible to keep up while counting backwards.
Phil Munson NY
07-18-2006 08:38:28
 Re: Why do they start the pulls with small tractor in reply to 720Deere, 07-17-2006 17:57:32
I would not argue with the merit of your comments. My computer is open; as in where the "little species" reads anything she wants. Being a happy married woose, as compared to being a man among men, I sure hope you got a delete button on your computer. If not, it has been a pleasure, we will miss you. :) best Yeoman
Funky Ford
07-17-2006 19:07:06
I'd rather pull my 8n before there are hills on the track than pull my 98 later. I'm pulling light and heavy when I bring them both. Not sure what the counting backwards and forwards deal means, maybe I'm stupid.
OU812
07-17-2006 19:50:49
 Re: Why do they start the pulls with small tractor in reply to Funky Ford, 07-17-2006 19:07:06
Why so much concern of the condition of the track,ie no blade or roller? After 50 or 60 hooks the track is the track. The point was why light tractors usually pull first.Reason,That's the way it was and change is BAD.
OU812
07-17-2006 18:12:39
Amen 720Deere.If it is anything like our area when we pull heavy to light the little guys are no shows. Real dedicated to the sport.
Jak
07-17-2006 13:53:03
I have spent a many late nights waiting to pull while the lighter pullers are enjoying the rest of the pull or are already home eating supper.We had one here local where the heavy went first and the lighter went last and you should have heard all the griping.
Jeff Oliver
07-17-2006 20:50:33
 Re: Why do they start the pulls with small tractor in reply to Jak, 07-17-2006 13:53:03
Ahh but remember while they lighter guys are sitting enjoying the end of the pull you have been sitting watching the first of it. I was at the heavy to light pull as well and thoughtit was gonna be cool th throw weight off instead of on but at the end of the day and I was tired I had to hang all that weight right back on my tractor to go home... 6 of one half a dozen of the other.
Jak
07-18-2006 10:36:10
 Re: Why do they start the pulls with small tractor in reply to Jeff Oliver, 07-17-2006 20:50:33
Awww but Jeff seeing the same little E Gleaners pass through 5 times from 3500 up does get a little monotnous.Occasionally where we are at they could have a full days pull with the battle of the Orange.Moving them weights keeps your discs in line don't it?Ha ha.Later Jeff.
G/MAN
07-17-2006 13:24:36
They don't always. Sometimes they'll run heavy to light, so that they're not always waiting around all day to pull.
redneckpuller
07-17-2006 07:47:35
another reason is that a lot of times the heavier class tear up the track for lighter classes. There are times, depending on the track, that by running the heavy classes first can make the track better.
colekicker
07-17-2006 06:48:11
Start with the small tractors and the sled's weight box is basically empty at some places so they can pull it. Just as the tractors are adding more weight, they will do it for the sled too. It can get old watching the same tractors if they don't have a hook limit.
My club has pulled from light to heavy on Saturdays and on Sunday afternoon we usually have a play day. On Sunday we start heavy and unload the sled so it can be moved.
Lots of people do it different ways.
