ac or champion plugs
jd plowboy
07-16-2006 09:11:08
what type of spark plugs do most pullers use in a stock oliver 88 with electronic ignition. had people say ac and some say champion.
RichB
07-18-2006 07:58:16
 Re: ac or champion plugs in reply to jd plowboy, 07-16-2006 09:11:08
I have used every plug concievable over the years,Champions are great sounders if you Ice fish,or as mentioned earlier a sinker for fishing,NGK plugs have worked the best for me,If you can find them AB6 is the plug that works best,I have never had a set foul.
Jak
07-17-2006 13:49:53
I run C87 AC plugs in my Super 88 Oliver with electronic ignition with suppression plug wires,no problems yet.3116 Autolites are my second choice.Champions are allright in a Chrysler product but not much else.Won't last long in a JD two cylinder before fouling.
JD hauler
07-17-2006 05:56:49
3116 autolites , great plugs
Ian Johnsen
07-16-2006 23:30:37
I wouldn't even put a champion in my push mower. Go AUTOLITE.
dboll
07-16-2006 19:34:49
Autolite currently has the best heat range selection, and are good plugs, AC has dropped alot of plugs and Champions are best used for fishing weights!!
gfs
07-16-2006 19:31:34
Let's see, how did that old tractor pulling commercial go," Tim Engler the mission impossible, 7 engines, 56 spark plugs, he trusts his to autolite shouldn't you?
ohio
07-16-2006 15:42:41
i use bosch or autolite, myself. if champion sent me a new set every day, i might consider them, and i would PAY ac not to send me any!
t.grim
07-16-2006 15:38:35
i still vote autolite 386 or388 depending on your engine
